any1 ever rebuilt thier own turbo?
a friend and i have a knackered std t3 turbo and most companies want £200 ish to rebuild it.
you can get the rebuild kits from flea bay, and we were wondering if we should have a go at doing it ourselves, it says no special tools are needed and any competent mechanic can do it,
seeing as he is a mech, and i was, were prob gunna give it a go,
if it proves too hard or something goes wrong we can get it properly done later
any1 else had a go?
how did u get on?
any1 else had a go?
how did u get on?
Passion for Fords!
as said it deffo needs balancng afterwards......the vibration of an unbalanced turbo will destroy the soft bearings in minutes
and when you say if it goes wrong you can get it done properly afterwards? ..... is that after the compressor wheel mashes and sends all the metal through the engine?
![Surprised](https://passionford.com/forum/images/smilies/shocked.gif)
DEYTUKURJERBS
Originally Posted by Versus_Creations
Building it is not that much of an issue.
WHO IS GOING TO BALANCE IT AFTER THE BUILD?
only need to do that is wheels are damaged etc and being changed.
Ask me a question!
I dissagree. I have built many Turbo's and use a local Garret Turbo dealer to balance my units every time. As said the comp wheel is locked in place via the nut (Left hand in most new built turbo's, std thread with old skool stuff) once that but is undone it will put the shaft and comp wheel out of balance. The chance of locking it back into place the exact same position is slim to none. A chance i wouldnt want to take risking my engine and filling the cooler, head etc with alloy.
Regards
I would personally get it balanced, but if you do strip and rebuild it, just mark the nut to the comp wheel, and count the threads showing, then put it back to EXACTLY the same place. Should not have changed the balance as no floating components have been changed.
Baby Cheesus
i rebuilt the one in my old 200sx
seal and bearing kit was £25iirc
like said, if you mark it all before you take it apart you should be ok
i forgot tho and remembered when i when i went to put it back together
was fine for the 2 months i had the car before i sold it, i used it every day too, and never heard the new owner have any probs with it
i must have put a good 600 miles on it, and i dont exactly drive like miss daisy lol
BUT - and here is the but...
my 200sx was a peice of shit, so if the tubo did shit itself, i would have give a fuck anyway...
but it didnt
would i rebuild the turbo im using on the 3dr myself and continue to nail it everywhere?
No, i woudnt take the risk on 7k worth of enigne for the sake of £200
well, that reply was totally useless
but it didnt
JK12
33
26-04-2021 12:09 PM
