Is it worthwhile drilling holes in airbox ? (Saph cossie)
Old 02-10-2007, 03:17 PM
  #41
foreigneRS
Testing the future
foreigneRS's Avatar
not if you're just going to suck in hot air.
so the plastic box is actually good at keeping hot air out?
yes - if it's fitted with the proper ducting that takes a cold air feed from the front grille (which is quite small and could be restrictive at higher than standard power)
personally, i would cut out the bottom of the box and a corresponding hole in the inner wing (with additional coarse filtration and water trapping measures) and use the high pressure air in the wheel arch to feed the panel filter with a large opening to that area from the front bumper
Old 02-10-2007, 03:44 PM
  #42
Mike Rainbird
Caraholic
Mike Rainbird's Avatar
Originally Posted by Ryan
mike, do either of the carbon airbox lids you do for the 2wd base, take a t34 size hose? or is one standard t3 and the other t4?
This one does . However, if you had looked at my website you would have seen that .
Also, how about this to help spice up the engine bay?
Old 02-10-2007, 03:51 PM
  #43
Paulo P
Paulo P's Avatar
Originally Posted by KSA-Cossie
Have you tried it yet m8.
Not yet I discovered that there is something pulling my cambelt onto the front edge of the pulleys and fraying the edge of it on the crank pulley so until that is sorted I can't drive it
Old 02-10-2007, 04:03 PM
  #44
Ryan
Ryan's Avatar
mike, i did look on the website but didnt see those pictures.
yeah im sure they would help, wouldnt really help the bank balance though.
Give me a special price on splitter, lid, heatshield, and full cambelt cover pls
Old 02-10-2007, 04:05 PM
  #45
pete mcrash
saff is working!!!...atm
pete mcrash's Avatar
chop it to bits................i got an airbox off Dave (cos 22)...it was concours... .i even sent him pics after i chopped the whole front off it.................it even had back to black on the inside........
Old 02-10-2007, 04:31 PM
  #46
Mike Rainbird
Caraholic
Splitter:
http://www.randbmotorsport.co.uk/sho...?ProductID=315
Lid:
http://www.randbmotorsport.co.uk/sho...?ProductID=143
Heatshield:
http://www.randbmotorsport.co.uk/sho...?ProductID=283
Cambelt cover:
http://www.randbmotorsport.co.uk/sho...?ProductID=103
You forgot something :
http://www.randbmotorsport.co.uk/sho...?ProductID=152
Old 02-10-2007, 05:29 PM
  #47
foreigneRS
Testing the future
foreigneRS's Avatar
what do you think you're achieving with that poxy squashed up corrugated pipe?
Old 02-10-2007, 10:14 PM
  #48
rapidcossie
rapidcossie's Avatar
so rather than drilling holes some people have just cut that big trianlge shape of the side of the air box?
anyone tested it?
Yes, AVA and it reduced the vaccum that was being created in Euan's airbox until he started to up the boost even more, and then the lid still started to collapse, so this is why he made his airbox bigger.
Mike is right...the lid of my box used to get sucked down until we cut the FULL fron off the bottom of the box.
Only thing we notced after doing this was that alot of radiant heat was now being sucked in from the back o fthe rad.
We blocked up the orginal square inatke in the box and made a sheild to stop this and bonded it to the back of the head light..
Old 02-10-2007, 10:16 PM
  #49
rapidcossie
new set up...
Old 03-10-2007, 05:34 AM
  #50
pete mcrash
......better than nothing u morron..........
Old 03-10-2007, 06:59 AM
  #51
Bullett
Bullett's Avatar
ive had the front and underneath drilled out of mine since i had it,tried a cone but it was shite.response was done and i hate the induction suck tbh.
every turbo'd car bar my pulsar has had a drilled box.
Old 03-10-2007, 07:20 AM
  #52
foreigneRS
Testing the future
foreigneRS's Avatar
what's a morron?
Old 03-10-2007, 09:09 AM
  #53
Andreas
Andreas's Avatar
While doing it make shure you dont cut the filler pipe for windscreen washer bottle.
Old 03-10-2007, 10:41 AM
  #54
rapidcossie
I now run a 3 door washer bottle
Old 03-10-2007, 10:54 AM
  #55
KSA-Cossie
KSA-Cossie's Avatar
new set up...
Impressive stuff euan.
Steve Escos
Ford Focus ST Parts for Sale
02-09-2019 11:39 PM
155lee
06-09-2016 11:10 AM
yatta
21-05-2016 10:31 PM
landaqmabba
15-09-2015 07:16 PM
Bransby
11-09-2015 09:12 PM
Quick Reply: Is it worthwhile drilling holes in airbox ? (Saph cossie)
