:wall: bloody car..
:wall: bloody car..
well i was geting a fluttering noise from around the turbo, and as adviced changed the spring iin my d/v..now i drove it down the road, it hit 18psi and then staggred like loosing boost, and im still getting the fluttering noise..
CAN ANYONE HELP ME AND TELL ME WHAT THAT BLOODY FLUTTERING NOISE IS
thanks
thanks
Originally Posted by milkman
Just sell up mate
How can that work, i drove it with the new spring in and it didnt flutter than after about 7mins it started to flutter again
thanks
thanks
its when i come off acelleration tho
Sounds like you've put a harder spring in the DV, so its not opening at lower boost and the air's going back through your turbo causing chatter.
changed it because i thouught it may stop the fluttering and it did for about 5 mins and then the fluttering came back..i changed it for a softer spring.. outlet is..25mm
forge dual piston ram dump valve
Rickeylee53, i said it feels like loosing boost, didnt say i was not accelerating, i said it flutters when iv accelerated and then depressed the clutch
Caraholic
If it flutters while you are accelerating and feels like it is loosing boost THAT IS SURGE!
Sounds to me like you have a completely mismatched turbo.
What rpm does it do it at?
No amount of dump valve changing will cure surge - you have to either cap the boost at the point it is surging or fit a smaller compressor or a larger turbine. You could also play with the cam timing to help allow the engine to "breath" better at the current surge point.
so if i brought a jap boost controller, would i be able to set it up myself? or best to go proffesional?
also mike do you mean mis matched as the compressor wheel is to big for the turbin or visa versa
well i had a t34.48 and stu wrote me a chip for that turbo,, but that turbo didnt last 5mins literally..so hadto get a new one made up..
would it be possible for stu to write a new chip to match my spec or not?
There lies your problem mate, get a 0.63 to 0.70 rear housing. This will free up horsepower (at the expense of some lag) and will get rid of a LOT of surge. (but not knowing what compressor you have I cant guarentee it'll get rid of it all)
Basically you need to spend some more cash
nipper.1
Ford KUGA
12
30-05-2022 07:39 PM
paceo
25-09-2015 08:05 PM
Si B
12-09-2015 06:49 AM
