Transit Luton
Newer licenses are limited to 3500kg, but older ones have a limit of 7500kg, as stated on my license, these are max weights loaded.
I think but am not sure by any means that the new regs came in around 99, but do not apply retrospectively so before that you are ok up to 7.5T.
Originally Posted by Matt J
just been on the DVLA site, its as tabetha said but the date was 97 when the regs changed, not sure on the weight of the luton I might be driving, is the average luton under 3500kg? or is it a 50/50 chance it will be a heavy un?
if it has the twin wheeled rear its almost deffo over. another thing to check, if its got a tacho fitted it could be over.
easiest way is to check the plate
90% sure you will be fine mate, doubt it will be over 3500 even if twin wheels, but as above check the plated weight, it will have a plaque on the inside.
all good fella
all good fella
van_dogg_pavvy
03-03-2016 09:30 AM
