boost holding back
boost holding back
escort rs turbo holding back when on boost hits 3psi an then cuts out drivers ok with half throttle
any ideas
had new turbo fitted actuator intercooler an grp a coil an chipped ecu
any ideas
Originally Posted by s1 2oobhp
even drove it with actuator pipe off an still no boost just hits 3psi an holds back
1 make sure there is no kink in the pipe from ecu to inlet manifold
2 make sure the actuator is set right ie enough preload around 5mm
3 check the timing if its been touched at all
if none of these work wack your old ecu on and see if that makes a difference, should still let you boost more than 3 psi
CabrioTurbo
01-08-2015 11:04 AM
