Headgaskets....
Old Sep 16, 2007 | 12:15 PM
BillyCabrio's Avatar
BillyCabrio
Default Headgaskets....
I need a new one
Driving the cabbie home from the garage its been sat in at my mates for the past year to my own garage earlier, plodding along giving it a 'few' beans and KA-POW white smoke eat ya heart out
Its running a standard Ford headgasket at the mo or it was, what should i replace it with? Don't really want to go thru this again if i can help it
Old Sep 16, 2007 | 12:33 PM
Fiecos Dan's Avatar
Fiecos Dan
Std's perfect, if fitted correctly, look after and no coolant issues.
Old Sep 16, 2007 | 12:44 PM
Christian and Beccy's Avatar
Christian and Beccy
#1 in Spelling Club
The OE Ford Gasket is the best one IMO, but you will need to get the head checked for alignment and pressure tested if you want to be sure.
Old Sep 16, 2007 | 12:46 PM
BillyCabrio
Thinking about it now, i think the one that was on it was a patent one from a local motor factors.
I'll get down Fords tomorrow then, should i get the stretch bolts while i'm there? Anything else i should get?
Christian and Beccy
What would of made it got like that? To much booooooooooost?
Old Sep 16, 2007 | 01:25 PM
©hatter Box's Avatar
©hatter Box
you need to ask you self why has it gone before putting a new one on if it was only a few years old paul if you need the bits let me know m8 i got them in stock
Old Sep 16, 2007 | 01:30 PM
BillyCabrio
I wouldn't have a clue why its gone Alex, its sat still in a garage for a year.
I'd let it tickover for at least 20 minutes before driving it and then brought it home, mind you i did give it some welly on the dual carridgeways on route.
Old Sep 16, 2007 | 01:43 PM
Stavros's Avatar
Stavros
DEYTUKURJERBS
det is what blows head gaskets.
fueling might be up the spout after sitting for so long.
Old Sep 16, 2007 | 01:52 PM
DanRSturbo's Avatar
DanRSturbo
Won't be the boost, it's only holding 16psi ain't it ?
Old Sep 16, 2007 | 01:58 PM
BillyCabrio
DanRSturbo
18 actually
Stavros
It was due to be set-up again as well
Old Sep 16, 2007 | 02:01 PM
AndyRST's Avatar
AndyRST
Which is about 6spi more than yours
Sorry to hear it paul, you sure its the H/G and not something else? get a leak down test and compression test done to confirm before taking the head off.
Is it possible the cheap motor factors H/G has corroded while its been sitting in storage and then you take it fo a blast and pop.
IMO you can't beat the std ford headgasket, would be perfect for your needs (was fine on my RST )
Old Sep 16, 2007 | 02:13 PM
Christian and Beccy
#1 in Spelling Club
Head Gaskets fail for many reasons. Such as....
1. Poor quality gasket
2. Head warped
3. Head cracked
4. Det
5. Incorrectly fitted/Torqued (caused by dirty/corroded threads in the block for example)
To name a few.
Personally, I would get the head into someone who can check it for the stuff I said. Then run an M10 tap down the holes and clean them out with brake-cleaner/airline, then refit the head with either a Genuine Ford or Payen head gasket and bolts. If you want to do the job a little more properly, coat both sides of the head bolt washers with Moly Grease before following the proper tightening sequence. That really is worth doing, but only if everything is clean.
Then, you'll be almost exactly where I am, with a setup that is putting up with 30psi etc. BTW, my gasket is Payen.
Old Sep 16, 2007 | 02:15 PM
haz87's Avatar
haz87
" coat both sides of the head bolt washers with Moly Grease "
How come Christian?
Old Sep 16, 2007 | 02:20 PM
BillyCabrio
AndyRST & Christian and Beccy
I'll reply fully later as i'm just off out, but its defo the headgasket as theres water all around the head/block meeting area behind the exhaust fanimold.
Thanks both for your help
Old Sep 16, 2007 | 02:22 PM
Christian and Beccy
#1 in Spelling Club
How come Christian?
You heard how the bolts 'creak' when you go through the tightening procedure? This stops that from happening so you don't feel like they might snap and not tighten them fully.
Also, if the washers/bolts bind as you are tightening them, it will give a false impression of them having reached the required torque.
Old Sep 16, 2007 | 02:26 PM
haz87's Avatar
haz87
Never even thought of that!
Old Sep 16, 2007 | 02:30 PM
AndyRST's Avatar
AndyRST
Another bit of help, You should have sprayed your cabbie white as we all know white ones were best, i mean look at Tony's and Christians
Old Sep 16, 2007 | 02:31 PM
Christian and Beccy
#1 in Spelling Club
Mines in bits and Tony's is in hiding!!
Old Sep 16, 2007 | 02:41 PM
AndyRST's Avatar
AndyRST
Minor problems
Blue Focus's are the way forward you know
Old Sep 16, 2007 | 03:04 PM
DanRSturbo's Avatar
DanRSturbo
Minor problems
Only because you can't handle a manly 1600cvh and hove to ponce around with a 2 litre zetec
Old Sep 16, 2007 | 03:11 PM
AndyRST's Avatar
AndyRST
Minor problems
Yeah couldn't handle the speed at which they rust
Old Sep 17, 2007 | 09:14 PM
BillyCabrio
Popped out today and ordered the Ford headgasket and stretch bolts, looks like Saturday is going to be busy
Old Sep 17, 2007 | 09:25 PM
GUZZLER's Avatar
GUZZLER
wake up Stav, theres many things that can cause a head gasket to go, if the car has been sitting for a year more than likley the gasket has rotted away.
Old Sep 17, 2007 | 09:43 PM
©hatter Box
take it you did not want trade then you could of picked up your lucky charms mmm
Old Sep 17, 2007 | 09:52 PM
BillyCabrio
I get trade at my local Fords mate
Oi! Keep ya hands off
Old Sep 18, 2007 | 06:49 AM
Fiecos Dan's Avatar
Fiecos Dan
i would of got a Payen gasket and non strench bolts.
£30 all inc.
Old Sep 18, 2007 | 09:56 AM
BillyCabrio
Fiecos Dan
I think the Ford one will do, i'm not running crazy bhp - my ickle 180 will do me
Old Sep 18, 2007 | 11:34 AM
*Anna*'s Avatar
*Anna*
Damn right you will be you gotta take me Birthday shopping first biach!!!
Old Sep 18, 2007 | 11:41 AM
Oranoco's Avatar
Oranoco
Get a Felpro
Standard Ford every time. Works for me on both of mine
Old Sep 18, 2007 | 11:51 AM
arch's Avatar
arch
Righto then, am I correct in thinking that Ford stock the gaskets etc? I need one for my S1.
Old Sep 18, 2007 | 11:52 AM
BillyCabrio
arch
Yes they do mate
Old Sep 18, 2007 | 02:23 PM
Tim's Avatar
Tim
always use ford bolts they look greenish on the sides and are coated so will not rust in and snap like lots of after market ones.
Old Sep 18, 2007 | 04:39 PM
Christian and Beccy
#1 in Spelling Club
Paul, Dan suggested the Payen one as they are the manufacturer of the OE gasket (it really is IDENTICAL except for the Ford logo), but they are usually cheaper.
Old Sep 18, 2007 | 05:54 PM
Fiecos Dan's Avatar
Fiecos Dan
As Christian Said.
£13 - £17 for a Payden H/G.
Old Sep 18, 2007 | 06:05 PM
BillyCabrio
Tim
Christian and Beccy
Fiecos Dan
Thanks lads, i didn't pay far off that for the Ford one
Old Sep 18, 2007 | 06:09 PM
Fiecos Dan's Avatar
Fiecos Dan
Fair play, i used to pay £38 for a ford H/G.
