DooR CarD RemovaL
reppin' passionford hard!
DooR CarD RemovaL
Holla, can any1 advise me on this. My rear windey window doesn't work on my mk5 escort (not my xr3i) so today i thought i would try woop off the door card to inspect it. Sadly, after unscrewing all the errr well screws!,,, the door card will still not come off. It seems all that is holding it on is the window winder itself which appears to be stuck fast. It doesn't rotate what-so-ever and i'm unsure of how to remove it! HELP! The winder itself is all one moulded piece of plastic so i cant seem to pop off any cap cover to unbolt it etc
what you want to do is
push the door card in where the winder is or pull the centre away away from the dorr card
you will see some sort of clip
this holds the winder t the frame, you need a little bit of bent metal or a bent screwdriver as a hook to get the clip out
job done
job done
03-11-2015 04:08 PM
