Cosworth engine too laggy?
DEYTUKURJERBS
What engines that turbo'd Mondeo engine in then?
I like the bracing etc to take the weight of the turbo, good work
Edit- I see above.
Edit2- Doubt its a "Noble" engine, just a built up turbo 3litre Ford V6 Duratec?
Edit- I see above.
The M400 engine that this is based on was 425bhp....
However, despite it using this as the base, I would say it is not as much as that with the current set-up. As Stav has pointed out, it must be running relatively conservative boost with such a small intercooler.
They just used the M400 engine as a base due to it's stronger internals (specced by Rousch), as the first engine (a normal Duratec) lunched itself at 130mph at Watkin's Glen
Originally Posted by JohnnyB
I thought the noble engine was a twin turbo,
about 320 bhp if your lucky
![Smokin](https://passionford.com/forum/images/smilies/icon_smokin.gif)
Awesome engine and a cool car Mike!
so whats sorta power could you squeeze out of a motor like that reliably ?
i want to set mymk2 granada up with big power next year , looking at all the possibilitys
what do they rev to as the BOA cossie v6 can get a little shitty after 6500
I have now changed to the BOB and will soon see it likes 2 turbos stuck on it
The above XR4Ti has a 3.0 duratec, the last time i heard it was still standard but with the turbo fitted. Although with a custom inlet.
The duratec can be fitted in to the sierra by using a Jag S-Type gearbox. The red one has an adapter plate to allow a Mustang T5 to be fitted.
Engine Machinist
i've had a look at all the bits he makes... some interesting stuff there
take a look on here for more ideas
http://www.merkurtech.com/merkurtech...pages/main.php
big_Rad
15-09-2017 09:36 AM
wheelwizardrefurbs
04-08-2015 06:23 PM
