boost problem
Old Sep 10, 2007 | 06:47 PM
JTECH James's Avatar
JTECH James
Passion for Fords!
Default boost problem
my shonkey saff has lost a bit of hold boost ,still peaking at 32psi, but it used to hold between 26 and 28psi, now its only holding 20
what do you think, im heading towards a weak actuator, as its 3 years old, and has a "bit" of pre load
cant think of any other reason tbh, no leaks etc etc
Old Sep 10, 2007 | 06:52 PM
Jay,'s Avatar
Jay,
Sponsor
could be a shagged actuator
Old Sep 10, 2007 | 07:14 PM
JTECH James
Passion for Fords!
thats what i reckon, i will call you if i get time later ,im working at the mo as usual
Old Sep 10, 2007 | 07:23 PM
Jay,'s Avatar
Jay,
Sponsor
ok mate
Old Sep 10, 2007 | 08:27 PM
pete mcrash's Avatar
pete mcrash
saff is working!!!...atm
are u using a amal valve..????
Old Sep 10, 2007 | 08:33 PM
col cos1's Avatar
col cos1
y do you ask that pete?
as mine was disconected last time at ava and now the boost is down...
Old Sep 10, 2007 | 08:35 PM
JTECH James
Passion for Fords!
yeah i have an amal, hence i still have the peak figure,
Old Sep 10, 2007 | 08:37 PM
Jay,'s Avatar
Jay,
Sponsor
theres no reason why u shouldnt on one of stus conversions chap he would have jetted it corectly
JTECH James
Passion for Fords!
i know mate ,the set up works very very well
Old Sep 10, 2007 | 08:49 PM
pete mcrash
try this................seperate the amal valve....top n bottom with a thin bladed knife..........inside is a spring and weight...take them out and put back together...........the amal valve still works, but not electricaly....i've done this on mine.....
Old Sep 10, 2007 | 08:56 PM
JTECH James
Passion for Fords!
how can the amal valve work, if it has no internals its just an electronic bleed valve,
i need the internals to work to get a peak figure , without the amal working i would only get a hold figure.....
Old Sep 10, 2007 | 09:02 PM
pete mcrash
...tell u what then, dont bother..............i've just said i've done it on mine......... ...mine works fuckn fine
Old Sep 10, 2007 | 09:04 PM
JTECH James
Passion for Fords!
it cant work wothout internals though can it its just an empty box
its not going to bleed electronicly when controlled by the ecu ,if it has no guts, it will just be dumoping air out of the return all the time...
Old Sep 10, 2007 | 09:05 PM
JTECH James
Passion for Fords!
heres a bit i wrote about amals a while ago...
Amal valve,or boost control solenoid as its sometimes called, this is how the ecu controls the amount of boost the turbo makes ,like an elactronic bleed valve in effect.
it also allows the boost to have a peak and hold figure, as the boost will spike when the valve is opening, then return to its hold figure when it closes off at the top of the boost range.
some people do away with them and just fit a bleed valve in between, but then you can only run the hold figure of boost and not have a nice spike to give a tad more torque where its needed
the amal valve basicly stops the wastegate actuator seeing the full amount of boost pressure coming from the compressor housing ,it does this by opening and closing a electronic valve, which bleeds some of the boosted air to atmosphere
take this example ,your wastegate actuator is set with a small pre load, and will open at 15psi.
the turbo is making 15 psi, so the wastegate should open preventing the turbo from making any more boost, BUT the amal valve is opening and closing very quickly allowing 5 psi to escape to atmosphere, all of a sudden your turbo is making 20psi before the wastegate actuator can see the 15psi it opens at. HERE IS YOUR PEAK FIGURE,
Then as the rpm climbs ,the ecu tells the valve to stop opening and it stays closed, the wastegate actuator can now see the full amount of boost made by the turbo and only allows 15psi before it opens the wastegate to prevent any more, HERE IS THE HOLD FIGURE.
__________________
Old Sep 10, 2007 | 09:06 PM
pete mcrash
dont bother then........easy...........if stu@msd said it u would say O.K......mine had this problem and Grove told me what to do.....its fixed
Old Sep 10, 2007 | 09:10 PM
JTECH James
Passion for Fords!
if you know how an amal valve works pal, removing the guts wont make it work ,simple as.
yes the car will still make boost ,but the amal valve will not be working, tbh you may as well have thrown it in the bin, and just piped from the wastegate to the comp housing, as fundimentally thats exactly what you have done
Old Sep 10, 2007 | 09:14 PM
pete mcrash
i have half a hole of preload (ish) and get a spike and a held figure....if ur valve is fooked or dodgy wirering.....this sorts it out.............if u dont want help/ideas dont ask..................tell u what it'll take 5 mins to do.....its ur problem not mine.................
Old Sep 10, 2007 | 09:18 PM
Jay,'s Avatar
Jay,
Sponsor
pete so how will a solinoide still control boost with its internals took out which are itengral to control air flow ?
Old Sep 10, 2007 | 09:21 PM
CossieRich's Avatar
CossieRich
Did Someone Mention TUV
He doesnt know as Grove told him to do it. Cant you read
JTECH James
Passion for Fords!
if you have half a hole pre load ,the actuator will open at a set pressure, you have nothing to bleed the air off as the amal valve isnt working
my valve isnt fooked, as it still has all its interanl organs and my wiring loom is new
Old Sep 10, 2007 | 09:22 PM
pete mcrash
just uses the jets.............i'm no expert fella........i had a simmiller prob,thought my wastegate penny was bent........it was a dodgy valve (wich was new) or wires.............it fixed my car.........
Old Sep 10, 2007 | 09:24 PM
JTECH James
Passion for Fords!
its normally the jets that are re-sized/removed to aid the bleed off of boosted air ,
not the valve internals
let me guess your problem was you couldnt get the boost high enough?
Old Sep 10, 2007 | 09:26 PM
pete mcrash
sorry for trying to help............... .........please dont listen me anymore.................
Old Sep 10, 2007 | 09:27 PM
Jay,'s Avatar
Jay,
Sponsor
mm i see where you goin my mate is a old lancia techi he used to put a jet in the pipe from the valve in his grailie to get it to produce and hold more boost but never took the internals out
JTECH James
Passion for Fords!
let me guess... your problem was you couldnt get the boost high enough?
im not being arsey, i can explain how it works pal
if im right ,your boost would have been capped at about 23psi ,and wouldnt go any higher, the fix would have been to remove the restrictor from the return to air filter port of the amal valve, thus allowing more air to be bled off, the valve basicly gets drowned by the increase in boost and cant get rid of enough to prevent the wastegate actutaor opening....
Old Sep 10, 2007 | 09:31 PM
pete mcrash
it stopped peaking and holding as much..........this eleviates an electrical problem............try it if u want...it'll not take long.............
Old Sep 10, 2007 | 09:33 PM
JTECH James
Passion for Fords!
ok, so if you wanted to reduce the hold figure, a simple turn off the pre load would have done that, and by playing with restrictor sizes the exact peak figure can be acheived, although i feel i am waisting my time here
pete mcrash
it dropped from 30psi to about 26/27..and held 25ish instead of 28
Old Sep 10, 2007 | 09:35 PM
JTECH James
Passion for Fords!
why didnt you take some pre load off the actuator arm?
Old Sep 10, 2007 | 09:36 PM
pete mcrash
...................i cant be arsed anymore................the boost went down.........i fixed it.....it went back up again.........simple................
pete mcrash
....wires crossed
JTECH James
Passion for Fords!
you DIDNT fix it
Old Sep 10, 2007 | 09:38 PM
JTECH James
Passion for Fords!
take an engine for example... would it still work as it was meant to if you removed the pistons?
Jim Galbally's Avatar
Jim Galbally
pete, jtechsaff seems to know how an amal valve works, please listen to him
Old Sep 10, 2007 | 09:40 PM
Nash's Avatar
Nash
Cake lover!
Now i know fuck all but if you rip the guts out of the valve wont it just be open and bleed air off all the time? Almost like having a hole in you vacum pipe? or am i totally off track?
JTECH James
Passion for Fords!
can someone take over here, i need a drink
Old Sep 10, 2007 | 09:41 PM
JTECH James
Passion for Fords!
no you are bang on the mark
Old Sep 10, 2007 | 09:43 PM
JTECH James
Passion for Fords!
when the valve is closed (hold) the wastegate actuator will see ALL the presure from the turbo, which opens acordingly
when the valve is opening and closing (peak) a percentage of the air will be bled off to atmosphere ,so the wastegate actuator doesnt see 100% of the turbo pressure so doesnt open untill much more boost is made, when it will see enough to open
Old Sep 10, 2007 | 09:45 PM
Jay,'s Avatar
Jay,
Sponsor
cant say anymore really
Old Sep 10, 2007 | 09:46 PM
Nash's Avatar
Nash
Cake lover!
Cheers J
