Who runs a Pectel T6 and could check something for me?
Old 11-09-2007, 07:20 AM
  #41
ian sibbert
ian sibbert's Avatar
Stu,
The drawing was done for the loom on my car...the pectel fax is just a typical wiring schedule, some people actually wire add on's slightly different...it shows the crank sensor grounded at both points (40 & 46) I dont think it makes any difference pal...
An obvious question pal, have you got the cutout on the 36 tooth wheel in the right orientation with TDC?
Ian
Old 11-09-2007, 07:53 AM
  #42
polly_x
polly_x's Avatar
Originally Posted by Mitsy FQ
fluxie i think he is on a 36-1 home made crank pulley
Yep....using a 36-1 crank pulley.
Old 11-09-2007, 08:12 AM
  #43
polly_x
polly_x's Avatar
OK, just to update as I am pretty sure I have narrowed it down to the phase sensor. Dont see that grounding issue being a problem as the crank is grounded to those separate pins and works fine.
Mitsi, ive tried inverting the phase but no luck. Thanks.
I am defo getting a crank signal. I see about 300RPM on the Deskpro when cranking
Iain, you pulley comments are making me wonder now! Ive had a 36-1 trigger wheel properly machined onto an original 2wd pulley in the place of the old 4 trigger points, but is it in the right place?
Not the best of shots but you can see how its done. Does anyone have a picture of an cossie 36-1 crank pulley that I can just compare mine to to be sure?
Also, any Deskpro experts.....what is the field name that you would expect to see a reading against for the phase? The only one I can see is Camhistory and that shows 0000 all the time.
Wheres Gareth when you need a nice comforting rub.............
Old 11-09-2007, 08:16 AM
  #44
ian sibbert
Stu,
The cut out is in the wrong place compared to a 909 t6 wheel I have at home....the cutout is not quite 180' opposite the keyway....if that makes sense....
Old 11-09-2007, 08:21 AM
  #45
Ryan
Ryan's Avatar
could this be NSYNC issue due to the trigger spacing?
now where have i seen that before
i.e cam and crank not syncronising?
Old 11-09-2007, 08:36 AM
  #46
Martin-Hadland
1st to 200 without NOS
Martin-Hadland's Avatar
My gap is at about 7 oclock with the keyway at the top
Old 11-09-2007, 08:45 AM
  #47
ian sibbert
Get that cleaned young man....dirty wheel....
Like martin says 7 oclock
Old 11-09-2007, 08:49 AM
  #48
Martin-Hadland
Believe it or not it was mint when my engine was built It's not getting used now as I'm using a Steel 36-1 with an alloy pulley..
Old 11-09-2007, 09:07 AM
  #49
Ryan
Ryan's Avatar
just spoken to polly x (stu) on the phone.
as no he's pretty sure this is the problem, as seeing in descpro
NOSYNC.
Think we've found it lads.
WELL DONE ALL!!!!!
Stu is going to report back tonight when he is near a PC.
Old 11-09-2007, 09:10 AM
  #50
Turbosystems
Super Moderator
Turbosystems's Avatar
to check you have a phase sensor signal out put use a meter on ac across the sensor pins
Old 11-09-2007, 10:41 AM
  #51
polly_x
polly_x's Avatar
NOSYNC.
WELL DONE ALL!!!!!
Yep......finally made it to a PC after sitting on the M25 this morning in traffic. Nice 56 plate R32 totalled into the central reservation!!!!
I think its this sync problem......As Ryan said it shows no sync in the deskpro and my pulley is obviously wrong.
I decided on having one made up as I needed to keep the normal fan belt config. Would be difficult to run a poly v belt as I have a tiny alternator setup on my car due to space. Maybe I should get a normal late escos 36-1 pulley and convert to poly v?
Cheers for all the help gentlemen....sure I will get there in the end and I owe lots of people beers and passenger rides should our paths cross in a pub or on a track!
Will update on progress later!
Old 11-09-2007, 10:42 AM
  #52
Rippers
Monte Geek
Rippers's Avatar
Maybe I will just buy a new YBP crank pulley from Ford then mate
Old 11-09-2007, 10:43 AM
  #53
polly_x
polly_x's Avatar
Actually looking at those pictures, it maybe that my trigger wheel needs unbolting and turning one bolt anticlockwise and it could be there!
Old 11-09-2007, 10:44 AM
  #54
polly_x
polly_x's Avatar
Maybe you should!!!!! I was so pleased with that setup too!!!!
Old 11-09-2007, 11:01 AM
  #55
ian sibbert
Stu,
Hope that sorts it pal....pic of a genuine T6 909 wheel to which the ally pulley bolts....
Ian
Old 11-09-2007, 11:05 AM
  #56
Porkie
Porkie's Avatar
Show off
Polly x, don't you just hate it when you get something that looks really cool but just won't work!
I had that with my MD240 Turbo! looked the part... was utter shite!
Good luck getting it sorted. Sounds like it is now
Well done all the chaps that helped
Old 11-09-2007, 11:06 AM
  #57
Turbosystems
Super Moderator
can't you borrow a standard pulley and set yours up to the same
Old 11-09-2007, 11:12 AM
  #58
Martin-Hadland
Stu,
Ian
That's what is going on mine
Old 11-09-2007, 11:16 AM
  #59
polly_x
polly_x's Avatar
Thats probably the easiest.
I reckon Iain should just send me that 909 one to help me set mine up.
Promise I will send it back
Are the 909 ones easy to get and can you get the normal twin fan belt pulley in alloy to bolt to it? Anyone got one in stock?
Old 11-09-2007, 11:20 AM
  #60
polly_x
polly_x's Avatar
Stu,
Ian
Iain, where is TDC on there? Can you mark it on your picture? Or somone post a picture of a standard pulley with keyway and TDC mark?
In deskpro you can set the degrees after TDC that the gap is. Can I just change that value instead of getting the pulley modified?
Old 11-09-2007, 11:25 AM
  #61
ian sibbert
Stu,
If you were closer pal, i'd bring it round...ive never seen one take a twin 'v' belt...they are all poly vee... I only have 1 poly vee bottom pulley, which is on my car
TDC is determined by the key, at 12:00 its TDC as shown in the pic off me and martin...use that as your datum, then as tony say just re-drill to suit your wheel...
The 909 ones are a little rare....i think ATM had one but they command top money....
Ian
Old 11-09-2007, 11:35 AM
  #62
Ryan
Ryan's Avatar
stu after looking at the picture if yours, i think its just not bolted onto the pulley correct just rotate the trigger wheel 1 bolt to the left?.
im pretty sure that will put the mark and 7 o clock?
Old 11-09-2007, 11:41 AM
  #63
Martin-Hadland
To covert to multi V (as per the EEC4 type) you only need water pump and alternator pulleys off a 4x4 model and it all bolts together no problemo..
Old 11-09-2007, 11:45 AM
  #64
polly_x
polly_x's Avatar
Martin, what tensions the belt? The same alternator adjuster as a normal fan belt setup?
Old 11-09-2007, 11:48 AM
  #65
polly_x
polly_x's Avatar
Martin/Iain, do you know what degrees your ECU is set to for the "degrees after TDC" for the Gap.
I think its in the ECU HARDWARE, ENGINE POSITION SENSORS, CRANK TRIGGER WHEEL setup menu.
Old 11-09-2007, 11:53 AM
  #66
ian sibbert
Logical Teeth 36
Missing 1
Angle of first tooth 280' atdc
missing tooth dtect cranking = .500
missing tooth dtect run = 0.500
trigger edge = falling
offset 1 = 0
offset 2 = 180
Old 11-09-2007, 11:58 AM
  #67
Martin-Hadland
Same as what Ian said... 280deg
Old 11-09-2007, 12:24 PM
  #68
polly_x
polly_x's Avatar
Logical Teeth 36
Missing 1
offset 1 = 0
offset 2 = 180
Coolio......thats what mine is set to, so its got to be that trigger wheel!!!!
Again, cheers for the input guys.
Hopefully we will have a runner tonight!!!
I am just gagging to get this out on the road with all the new engine, gearbox and weight saving bits!!!!!!
Old 11-09-2007, 01:39 PM
  #69
GARETH T
GARETH T's Avatar
you dont have to change the crank pully,, you can just change the offset, very simple in the software
Old 11-09-2007, 02:06 PM
  #70
DazC
DazC's Avatar
I was just thinking that as i was reading this myself! Why not just change the software settings!
Old 11-09-2007, 03:00 PM
  #71
polly_x
polly_x's Avatar
Yeah.....easy if you know what to set it too!!!!!
Answers on a postcard.
I may just keep changing it 10 degrees at a time in the map and check rather than remove the pulley and remount the wheel.
I should get it right after a maximum of 36 attempts!!!!
Old 11-09-2007, 03:02 PM
  #72
GARETH T
GARETH T's Avatar
once you got the right setting, why would you then want to remount the wheel on the pulley?
Old 11-09-2007, 03:05 PM
  #73
ian sibbert
150 degrees?
geometry was never my strong point....i reckon it wants to be 130 degrees more or less with the pulley as Stu has it at the mo...
Old 11-09-2007, 03:08 PM
  #74
Porkie
Porkie's Avatar
Logical Teeth 36
Missing 1
offset 1 = 0
offset 2 = 180
make your first drive over to Billericay mate
Old 11-09-2007, 03:16 PM
  #75
polly_x
polly_x's Avatar
Logical Teeth 36
Missing 1
offset 1 = 0
offset 2 = 180
Billericay!!!.....That means I will have to cross the border into Essex. Do I need a VISA or anything?
Old 11-09-2007, 03:27 PM
  #76
GARETH T
GARETH T's Avatar
150 degrees?
i counted 120 degrees out quickely,, but hay it would give a good starting point
once its running theres a accurate was you can get the correct number
clock an accurate TDC, then mark from a static point (i use the sesnor body) around the pulley and mark on the pullyy in a line
using a digital timing light, start the car us, and gain a steady idle,!
look on descro desktop to see what the actual ignition advance is (total)
dial this advance number into your digital timing light
your two original marks should line up under the strobe light, if they dont adjust the advance/retard on your timing gun till they do
now subrate you descpro total from the figure you have on your gun!
this number needs to be added or subrtracted from your "angle after missing tooth" figure in your software
sorted
Old 11-09-2007, 04:26 PM
  #77
Ryan
Ryan's Avatar
come on stu, updates
Old 11-09-2007, 05:18 PM
  #78
ECU Monitor Enthusiast
I suspect you have other issues as irrespective of the position of the
wheel, it still would have "synced" and it didnt. Just my 2p worth.
Old 11-09-2007, 05:25 PM
  #79
polly_x
polly_x's Avatar
tried 110, 120, 130 and 140 with phase normal and inverted for each.
Nothing.
In deskpro it says "Sync_Mode" NONE
Any more ideas?
Old 11-09-2007, 05:27 PM
  #80
polly_x,
Have you tried reversing the crank sensor pins
Quick Reply: Who runs a Pectel T6 and could check something for me?
