anyone know how to adjust the handbrake on a new mini?
right this should work....
lift the hand brake gater
slacken the cable completely
Take the caliper off
remove pads
wind back the piston (tool needed but its not that "specail")
re-install the pads
put caliper back on
pump the pedal 3 times
then set a 2-3mm gap between the hand brake lever and the notched pin using the cable (ie tighten the cable and set the gap on the caliper).
WARNING
If you set them up wrong the problem is that the handbrake will simply release when the car is standing!!!!!!
This is only a rough guide to get you started - it is not detailed and I do not gaurentee this information! You undertake this work at your own risk!
Alex
[/b]
remove pads
re-install the pads
put caliper back on
WARNING
Alex
[/b]
SMILER258
28-09-2015 09:04 AM
