BMW E36 Electric window help???
Old Sep 4, 2007 | 09:32 PM
RS Bowk's Avatar
RS Bowk
Default BMW E36 Electric window help???
my windows are playing up in my 4dr E36 BMW.
Basicly when you go to put em up on the one touch button they get allmost to the top then fire back down again almost as if something has obstructed its path. Ive also noticed that when i put the window down it jolts forward slighty, thus making the window sit just out of place. Will this be the cause and if it is how do i cure this?
If not any other ideas?
http://cgi.ebay.co.uk/ws/eBayISAPI.d...MEWA:IT&ih=015
would these cure the problem? I believe this is a common problem for BMW's
Your help would be gratefully received as its starting to f@*k me off.
Old Sep 4, 2007 | 09:49 PM
puddy's Avatar
puddy
If it has had new regulators fitted at some point(most have),they may have
used alloy pop rivets to mount them to the door.They come from the
factory with rock hard steel mounting rivets,only thing you can do is take
the door panel off and check for movement on the rivets.
puddy
Old Sep 4, 2007 | 10:20 PM
RS Bowk's Avatar
RS Bowk
Where abouts am i looking for the regulators Puddy?
Old Sep 5, 2007 | 04:10 PM
RS Bowk's Avatar
RS Bowk
Anyone else able to help ???
Old Sep 5, 2007 | 05:43 PM
Dangerous Malcolm..'s Avatar
Dangerous Malcolm..
Have you looked on e36coupe
Old Sep 5, 2007 | 07:28 PM
RS Bowk's Avatar
RS Bowk
Nope. Will try it now tho as i think this is probably a common problem.
Old Sep 5, 2007 | 10:43 PM
puddy's Avatar
puddy
You will have to take the door trims off of the inside of the doors .
puddy
chowfornow
14
Jan 5, 2019 09:01 PM
Nov 1, 2015 06:53 PM
Oranoco
12
Oct 2, 2015 02:18 PM
stevecfrst1
Sep 30, 2015 05:18 AM
cossie330
Sep 27, 2015 04:13 PM
