T34's covering old ground
#41
Originally Posted by JTECHSAFF
if i had to chose a new turbo i would not get a roller bearing tyoe ,because as far as i understand, if they go wrong ,its basicly disposable and very expensive to replace, can fail because of even slightly dirty oil ,where a standard type will still be ok,this means changing oil even more often and the bearing carriers are made of plastic, and can melt
motors reckons a lot of problems with gt turbo's stem from too much oil
being pushed thru them,and runs restrictors in the oil lines.
This also means better engine oil pressure.
puddy
Russ Payne
25-09-2015 08:29 PM
