idle trouble with cossie, any idea ??? [SOLVED]
My cossie has some idle problems....
the rpm change every time from 550 to 1500, the AFR change too from 1.03 to 0.13
i had checked the idle valve, and had tried to change the idle screw and the CO trim, but it's the same.
i have siemens 55 lb with closed loop chip from stu
any idea ????
any idea ????
Is it from cold start or does it go after a few mins??
Mine was terrible until i changed my plugs then had it mapped, it was up and down 500-1500 too, mind you i'm saying go and have it mapped @ 300 plus quid a time mine was booked for mapping, but i;m trying to let you know how mine was..
today, i had dimounted all part of the idle valve, i had cleaned and after a touch of wd40 ....
and know, it s work fine
i had already clean the valve last time but i hadnt dismounted all parts
so, the best way is to dismount completly the valve and clean
if you know somewhere with a chemical cleaning bath you can stick it in there without dismantling it completely and it should be squeaky clean im currently removing mine as i have the same problem
