Deristricting rally spec Cossie motor
OK.To get my Puma up and going I'm gonna put the rally engine back in.Now it's a good strong long studded motor,pro ported but it's on 9.1 comp ratio.I've got BD14's to go in and i'm taking the restrictor off the turbo.I will change the map in the ecu but will it be safe at this ratio on 99 octane.The present map runs air to air,anti lag and water injection.So boys,can it be made safe on 9.1 comp?
That sounds a bit more like it.I'm gonna miss my Reyland motor but will have to make the best of it.Got a proper gearbox and big diffs now and ca'nt afford the motor.
Don't the scandinavians run big boost on high cr's ??
I ran 8.6:1 and put a big turbo (GT35) on it.... and we all know what happened there.
But it was fine with a T4 at 28psi. I'm sure you could run some "decent" boost with a T35 but the setting up of it would be very important!!
they all seem to get thrown about round quite short tracks.
most prob on funky fuel too.
