Cossie remote oil cooler and water pipes?
RWD Racer
How are peeps plumbing the two water pipes to the oil cooler housing if using a aftermarket remote oil cooler on a cossie?
Seems a daft Q but if you do away with the std water cooled housing do you just plumb the two pipes together,
or is there a extra long bolt to run both water and remote housings together?
RWD Racer
No stat with this kit
Im replacing me engine in me escort n the replacement engine has a remote oil cooler kit fitted, so would like to keep it as a bonus
Not essential as I could retro fit the old bits but I would pref the freebie remote cooler idea
RWD Racer
what about getting a big wing sump,don't think an oil cooler is needed then,but i suppose it depends on your spec.
Will be running stg 3 for now
RWD Racer
Nope, just plain ol stg 3
Anyway it's fitted now so it's endeed up with it rigged up like this.
Top hose from the water pump up n over the rocker cover to the rear head tack off point
Not sure if I will end up with an air lock as the top hose runs over the rocker cover n is as high as the header tank atm ?
Ford Focus RS Parts for Sale.
02-06-2016 06:46 PM
09-10-2015 07:38 PM
