How much power can be lost on an out of tune cossie ?
Originally Posted by mechanic28
in all truth there is only 3 things to check really boost,fuel pressure,co all the rest is set
A common problem on cossies is crank pulley wear and is usually overlooked.
The woodruff key way wears allowing the pulley to move with respect to the crank shaft.
This causes the ignition to be retarded in most cases losing power and in
extreme cases, causes ignition to be advanced which could lead to a melt down !
I had this exact problem many years ago.
Think ive found a car im finally happy with , tbh never really took to the cossies for some reason , heart was never truely in it, can you believe i dont want to drink so i can run about i my car
NC53
13-09-2015 03:05 PM
