..if you was buying an mitzi EVO
Old 22-08-2007 | 08:04 PM
Deleted by Request's Avatar
Deleted by Request
Former Sponsor
Default ..if you was buying an mitzi EVO
...is it worth spending xtra on the 6 over the 5?
7.5k gets a good 5...but you need to spend 2-3k more on the 6..but to me they look the same although the 6 is faster to sixty at 4.3 secs against 4.6 accoreding to figures
Old 22-08-2007 | 08:12 PM
Deleted by Request
Former Sponsor
...are you implying i take drugs?
Quite possibly...i am sposed to be a dealer but i have nothing left to sell
Old 22-08-2007 | 08:14 PM
ECU Monitor Enthusiast
I would get the 5 and mod it. 6's are over rated IMO
Old 22-08-2007 | 08:16 PM
Carlsworth's Avatar
Carlsworth
Former Sponsor
i looooooooooove the looks of the 6
my fave evo
dont think id buy one though
carl
Old 22-08-2007 | 08:17 PM
Deleted by Request
Former Sponsor
..but how is the 5 different from the 6?...In terms of why you would buy?
Old 22-08-2007 | 08:20 PM
Rob84's Avatar
Rob84
I'd personally go for an Evo 5 RS. has more road presence then the 6 imo and is without all the AYC etc (not that you'd need it anyway, the way you drive ) and has the super strong rear diff (again... not that you'd need it!!)
evo 5 RS FTW
Old 22-08-2007 | 08:22 PM
saff_cossie's Avatar
saff_cossie
Go the 6 minimum but to be honest but I would be looking later models depending on how long you plan to keep it for.
I would stay away from the earlier models, great cars but they will need more general maintenance than the later models, sooner.
Old 22-08-2007 | 08:24 PM
Deleted by Request
Former Sponsor
..the 5 and 6 look identical Matt J
Old 22-08-2007 | 08:27 PM
Staffi's Avatar
Staffi
Evo 5 RS Phil, no AYC nice strong diff, light weight, very capable car in standard form...
Old 22-08-2007 | 08:29 PM
Mark Shead's Avatar
Mark Shead
Phil
Truthfully they are both the same but Tech the 6 is the best and it prob is,
I would buy a 6 over a 5 but if they wasnt a 6 I would buy a 5 .
Mark
Old 22-08-2007 | 08:36 PM
Uncle Winnett's Avatar
Uncle Winnett
haveing owend a 5 rs and a 6gsr
id look at both 5 rs and gsr and 6 rs and gsr just get the best car you can the rs has a stronger diff and is lighter and also has a shoter gearing so gets to 130 quick but thats it where as the gsr will go on to 150
john
Old 22-08-2007 | 09:11 PM
Carlsworth's Avatar
Carlsworth
Former Sponsor
i thought the evo 6 had a different bumper....
i know theres not much in the looks, but for me the 6 looks soooo much better for some reason...
did they have different wheels to the 5, maybe its that if they did
carl
Old 22-08-2007 | 09:13 PM
rapidcossie's Avatar
rapidcossie
evo 6 has alot of differances lookswise from 5.
Old 22-08-2007 | 09:15 PM
MikeR's Avatar
MikeR
Phil, l really like the 6's they look mean and are really raw looking what l wanted but got the deal on the 8
Mike
Old 22-08-2007 | 09:20 PM
jameswrx's Avatar
jameswrx
Phil, here's some of the differences as listed on MLR model info for the Evo 6 over the 5..
Evolution VI arrived with some fine tuning to its aerodynamics after changes in the 1999 WRC regulations restricted the size of aero attachments, and a dramatic improvement in cooling performance.
Cooling was improved by offsetting the license plate and using smaller fog lamps to enable the effective area of the bumper openings to be enlarged, while new ventilator and airflow ducts in the bumper enhanced the performance of the oil cooler. Drag was reduced with the use of hemi-spherical fog lamp covers, while the introduction of a twinwing reardeck spoiler design made up for the reduction in downforce resulting from its smaller size. Evolution VI's engine generated the same maxima as its predecessor but detail modifications improved reliability and response. A titanium-alloy turbocharger turbine - a world first - on the RS model improved throttle response, while the addition of a cooling channel in the pistons improved reliability.
Increasing coolant circulation by changing the layout of the coolant passages reduced cavitation. Improvements to the oil pan baffles and the use of an uprated oil cooler stabilized oil temperature at high engine loads. Detail changes to the suspension included: greater stiffness resulting from the use of forged front knuckles, and a lowering of the roll center by transferring the ball joint from the forged aluminum lower control arm to the knuckle, both resulting in better tire-road contact. At the rear, the use of forged aluminium for the lower control arms, trailing arms and toe control arms reduced the unsprung weight of the vehicle. A longer rebound stroke also improved tire-road contact. Body stiffness was increased with an additional 130 spot welds, the use of structural adhesive and the use of thicker gauge sheet metal in some panels. These detail changes enabled Evolution VI to achieve new peaks in terms of response, grip and handling stability.
Old 22-08-2007 | 09:21 PM
Mark Shead's Avatar
Mark Shead
carl
Suspension arms/nuckal joints/turbo/ecu/front bumper/rear spoiler/seat colour/dash colour/brake caliper shims/pistons/rods/oil spray jets/oil cooler,
I am sure there are some other bits but I cant remember of the top of my head.
Mark
PT's Avatar
PT
Evo 5
Evo 6
Old 22-08-2007 | 09:22 PM
Mark Shead's Avatar
Mark Shead
jameswrx
You beat me to it
Mark
Old 22-08-2007 | 09:27 PM
jameswrx's Avatar
jameswrx
Gotta be the 6 if funds permit IMO.
I love the Reims blue (as above) look superb on a set of rrefurbed darker rims. You'll love one at circa 350bhp, and they are pretty straight forward to get to that.. and they'll be nice and reliable.
Old 22-08-2007 | 09:41 PM
morto's Avatar
morto
not much between them realy , ive been reading up on mlr and cant see a big diff between them , but i wud go for the 6 probaly go down the rs route as ayc can be a pain up the bum, just for abit of info did you now the turbo,s spin in the oppisite direction from the 1 to 3 at first i dident believe it till i read it on 2 diff web sites
andy
Old 22-08-2007 | 09:42 PM
Uncle Winnett
5rs
6 gsr
john
Old 22-08-2007 | 10:02 PM
MikeR's Avatar
MikeR
I love the Reims blue 6's also the only problem is i was forced to go out in one with 650bhp dam you Mark
Mike
Old 22-08-2007 | 10:13 PM
Chip's Avatar
Chip
*** Sierra RS Custard ***
Evolutions are appropriately named, every time a new one is brought out it is better evolved than the last.
Later = better
Id still have a 5RS if it was me though!
Old 22-08-2007 | 10:20 PM
RS_Ant's Avatar
RS_Ant
The only evo id ever even considering buying is the Evo 6 tomi mak
Old 23-08-2007 | 01:27 AM
Charlie Chalk's Avatar
Charlie Chalk
Unknown.
Uncle Winnett
Looks nice on the new comps
Old 23-08-2007 | 05:38 AM
Redkop's Avatar
Redkop
jameswrx
Captain Mike
Those pics above aren't of Rheims blue cars.... they are of Icelle Blue ones.
This is Rheims blue, it's much lighter and it isn't a metallic finish
Icelle Blue
Old 23-08-2007 | 07:06 AM
D19 STE's Avatar
D19 STE
On MLR there is a model comparison section for all models
Here is the link for 5 vs 6
http://www.lancerregister.com/mlr_sh...?id1=10&id2=12
Old 23-08-2007 | 08:35 AM
Cawood's Avatar
Cawood
i wouldn't mind know a bit out em, im planning on selling the saff soon n getting a EVO 5
how reliable are they? expensive to maintain? etc
Old 23-08-2007 | 10:06 AM
Uncle Winnett
Uncle Winnett
they are bbs wheels compmotive got the desigin off bbs
john
Old 23-08-2007 | 10:09 AM
Deleted by Request
Former Sponsor
...TO AN UNTRAINED EYE THE 5 AND 6 LOOK THE SAME TO ME
Now i see both together you can see quite a differenvce so i accept the and you may call me a cunt.
...trouble is though...i then look at the 7 which is just chalk and cheese lookswise...less aggressive but much more modern
Old 23-08-2007 | 10:11 AM
Chip's Avatar
Chip
1/2/3 are protons and essentially the same
4/5/6 are all essentially the same
7/8/9 are all essentially the same
Its basically 3 revolutions and 6 evolutions effectively
Old 23-08-2007 | 10:12 AM
Redkop's Avatar
Redkop
Go on MLR and click on Articles. Loads of info available there.
Old 23-08-2007 | 10:18 AM
Turbosystems's Avatar
Turbosystems
Super Moderator
ok to maintain when new expensive as they get older and more miles just like a cosworth
Old 23-08-2007 | 10:23 AM
saff_cossie
Spot on the money. I have heard numerous people on here say how Jap is better than Cossies but if you go out and buy a 15 year old performance car, it is going to cost you similar money wherever it has come from in the world. The reason Jap is perceived to be better is because a lot of the cars are a maximum of 10 years old that are talked about but most are a lot less than that
Here is a link to some pics of BigPower's and my VII if you are thinking down that path now:
https://passionford.com/forum/viewto...385&highlight=
Old 23-08-2007 | 10:31 AM
Turbosystems
Super Moderator
I cured all my old cossie repairing problems i bought a brand new one but it wasn't a cosworth only because they don't make one
so far i have done 3k miles and the maintance bills have been 0 what a surprise
Quick Reply: ..if you was buying an mitzi EVO
