MD116 Turbo - Whats That?
DEYTUKURJERBS
a turbo dynamics one.
will be a garrett that they have renamed to look flashy and clever, as usual.
no idea on the spec, wont be anything wild or crazy tho, but if its anything like a MD240 it will surge like a cunt/
1 Post
found it
Quoted from them
MD116 Modified T34 Compressor cover, compressor wheel and backplate , 360 degree ramped thrust bearing, modified backplate and bearing housing, left hand thread shaft wheel, twin racing “Hi Temp” piston rings, 0.63 A/R turbine housing. Maximum Recommended boost pressure 22-24 P.S.I. - Uprated –31 actuator standard. Approx - 360BHP
Quoted from them
Originally Posted by Jasesapphy
i will dig the spec out for you, but if i remember right
Usual T34, 360 bearing yada yada
Although I don't have a spec! lol
1 Post
Garrett Turbocharger – Part No. 452059-0001 – Ford Part No. YB1195/2- 1992->96
Stage 1 Stage2 Stage3 Stage4 Stage5
MD158 MD116 MD153 MD122 MD164
Brief Specifications: -
MD158 Modified T34 Compressor cover, compressor wheel and backplate , 360 degree ramped thrust bearing, modified backplate and bearing housing, left hand thread shaft wheel, twin racing “Hi Temp” piston rings, 0.48 A/R turbine housing. Maximum Recommended boost pressure 20-22 P.S.I. - Uprated actuator optional. Approx – 330BHP
MD153 Hi flow GT32 compressor wheel, C.N.C. re-profiled compressor housing, 360 degree ramped thrust bearing, modified backplate and bearing housing, left hand thread shaft wheel with cut back blades, twin racing “Hi Temp” piston rings, 0.63 A/R turbine housing. Maximum Recommended boost pressure 24 - 26 P.S.I. - Uprated – 31 actuator standard. Approx – 400 BHP
MD122 RS500 compressor cover, compressor wheel and backplate, 360 degree ramped thrust bearing, left hand thread shaft wheel with twin racing “Hi Temp” piston rings, 0.63 A/R turbine housing. Maximum Recommended boost pressure 28-30 P.S.I. - Uprated – 34 actuator standard. Approx – 450 BHP
MD164 RS500 compressor cover, Hi Flow 60 Trim compressor wheel, 360 degree ramped thrust bearing, “M247” Martinite left hand thread shaft wheel with twin racing “Hi Temp” piston rings, 0.63 A/R turbine housing. Maximum Recommended boost pressure 30-32 P.S.I. - Uprated – 34 actuator standard. Suitable for running A.L.S. Systems. Approx – 500BHP
JK12
33
26-04-2021 12:09 PM
