help cossie problem
Old Aug 17, 2007 | 08:37 PM
Hansenturbo's Avatar
Hansenturbo
Default help cossie problem
A m8 of mine has a sierra cosworth 4x4 and we have made it ready for mot its std chip and inj the problem is the can rev fine on standstill but when we try to drive the car it constandly cut out and can`t drive
we have checked the TPS but its ok could this be wrong fuel pressure or maybe one of the sensors ??
Old Aug 17, 2007 | 08:46 PM
Butch.'s Avatar
Butch.
sounds like the map sensor, as when you rev on standstill no boost as soon as you drive no fuel for boost and cuts out
Old Aug 17, 2007 | 08:54 PM
Hansenturbo
okay thanks m8 ill tjek the mapsensor but the car running 1-2 psi cos its going to MOT so could it still be the mapsensor at so low boost ?
Old Aug 17, 2007 | 09:00 PM
Butch.'s Avatar
Butch.
thats the only thing that sees vaccum and boost
Old Aug 17, 2007 | 09:01 PM
Hansenturbo
ok ill try that thanks m8
Old Aug 17, 2007 | 09:23 PM
Hansenturbo
can we just disconnect the map sensor to see if its the problem?
Old Aug 17, 2007 | 09:26 PM
JTECH James's Avatar
JTECH James
Passion for Fords!
no it wont run, you need to try another 2 bar item
Old Aug 17, 2007 | 09:27 PM
Butch.'s Avatar
Butch.
no it wont run at all with that disconected you will have to try another on it to see
JTECH James
Passion for Fords!
Old Aug 17, 2007 | 09:33 PM
Butch.'s Avatar
Butch.
Old Aug 17, 2007 | 09:35 PM
Hansenturbo
ok thanks its on a 3bar map sensor but all the parts are std could that be it ?
but ill just have to get a 2 bar mapsensor and try that
Old Aug 17, 2007 | 09:36 PM
JTECH James
Passion for Fords!
i had a dog and his name was "BINGO"
it wont run very well if at all, on a 3 bar if its got a standard chip, the voltages are wrong at different boost/vaccum levels
Old Aug 17, 2007 | 09:39 PM
Hansenturbo
thanks guys
marky_g
Sep 12, 2015 04:26 PM
morg65
Escort MK 5 / MK 6
17
Sep 11, 2015 08:40 PM
Thanasis
Sep 7, 2015 07:33 PM
routemaster
Sep 7, 2015 05:27 PM
