cossie blue smoking on full boost?
ok
need some help please lads
the last couple of days my car has used almost 2 sumps of oil
now as im usually out at night i carnt see any smoke
so today i took it for a blast
it only smokes when full boost is hit accelcerating, let off and nothing on over run
nothing when it starts up from cold, or just general driving about
so i thought it would be my rings, but i done a comprssion check and they are all on 140psi bang on
so now i think its top end
the turbo is fine aswell
so this leaves me with valve guides or stem seals i think?
but if these are worn then wouldnt they smoke on start up when cold
could anyone shed some light as what the problem could be
as its really annying now and costing me and arm and a leg in oil
there are no leaks and no contamination in water either, so its definitly burning it or spitting it out the exhaust either way
also would a leak down test tell me anything, if so how do i do it?
thanks
engine is std internally bar grp a gasket and running stage 3 at 25psi
thanks
thanks
thanks
i doubt it would be the top end using that much oil, i would say rings mate but how gutted are you guna be if you JUST put a set of rings in it and it doesnt cure it.......your beeter off getting a new set of pistons and getting the block bored and doin the whole job right rather than just risking doing the rings..
Have fun whichever way you choose
reason i say its not rings
is the oil ring is at the bottom so if the compression test is exactly the same across all 4 then surely it wouldnt be gettin to the oil rings
what do i need to do for a leak down test as this will tell me if the oil rings are knackered would it not?
i dont want to take the engine out if its top end which im thinking it is
a head is easier to take off and have done than take the bottom end out out
so if i can get to do a leak down test and this comes back ok i know its not the rings
internally the engine looked like new, still had honing marks in bores and has only done 80k at std boost until i chucked 25 psi down it a wekk later and its doing this
oh ad it only smokes on full boost i can run around 18 and it doesnt smoke
turbo is fine
if teh turbo seal was gone then it would do it on tick over ?
breather is a spec-r grp a breather
breaths from inlet,crank under turbo, rocker cover all ito a seperator and into a catch tank
the catch tank has a tiny bit in it thats it
i know the breather is upto the job
i only know how to do a normal compression test mate
whats this wet and dry lark
do you mean fill te bores up with oil and then do a compression check?
usually when a turbo oil seal has gone it would be smoking on tick over as its dripping into the exhaust housing and there would usually be a leak on the core somewhere
plus it would do it at any set boost amount not just on full
i can have the turbo checked out for nothing as its brand new just means the car not on the road for a couple of days but im 100% its not turbo
ill do it tomorrow now then
ive just looked at the water and it looked black?
so just done a water change and it was clear no anti freeze in there well it wasnt blue water anyhow and i know it had antifreeze in it
so just refilled again and the water going back into the tank was white but has no cleared up
so could it be headgasket now
i dont know really starting to annoy me now and i think im going t have to pull the lot out and do a fresh rebuild
more money than what i wanted to spend on the thing
think ill wait until something bad happens now unless its self destructs
Escortdriver1
31-07-2015 02:36 PM
