POLYCARBON WINDOWS, HOW TO POLISH??
Old 16-08-2007 | 09:12 PM
Hooligan's Avatar
Hooligan
Default POLYCARBON WINDOWS, HOW TO POLISH??
I bought an ex-ME (Dutch equivalent of SPG I think) truck wich, amongst other things, is fitted with polycarbon windows.
You can barely see through the front-side windows as the surfaces has tiny scratches in it and it has weathered due to general use and exposure to all sorts of weather.
I reckon if I can polish the toplayer they will become transparant again?
How to polish them, what can be used?
One of the extra's on this truck is that is has a shute in the floor that was used to drop teargasgrenades from
Another extra is the 40 kg bulletproof grill
It's powered by a 3.8 litre 4-pot diesel with a slushbox and it is what they call an industrial diesel wich means it'll run on just about anyhting and has a longer life expectancy that the current owner
Old 16-08-2007 | 09:14 PM
Deleted by Request's Avatar
Deleted by Request
Former Sponsor
...i reckon Simon SECS will be needing a ride like that soon
Old 16-08-2007 | 09:17 PM
Bomber's Avatar
Bomber
If the polycarb has been subject to lots of UV then no amount of polishing will help it - you might have to get new ones made. They only have a life span of about 2.5years.
I use Poorboys Spray and Gloss (its an anti-static spray for the buftys) on my polycarb windows and use a microfibre cloth to wipe it clean. Using a sponge or cloth will leave scratches. If you havent got access to an antistatic spray just wash them with warm soapy water, but you need to use a microfibre, anything else will scratch it.
Old 16-08-2007 | 09:22 PM
Hooligan's Avatar
Hooligan
Not the answer I was hoping for
See, they are set in huge steel frames as they are ment to be bulletproof so removal will probably take ages and be an akward job
I do so love my new 'van' though, at nearly 4 metric tonnes it's not quick but it'll easily drive through a house
Old 16-08-2007 | 09:28 PM
Kevin Sharp's Avatar
Kevin Sharp
Pics or STFU forgein bloke
hows it going mate?
Old 16-08-2007 | 09:31 PM
Hooligan's Avatar
Hooligan
Oi Kev!
I'm allright mate, you??
It's a Merc 508 with double air
Will try to sort some pics next week.
it only did 30.000 KM untill now and I've got full servicehistory and all that for it.
Driving a Jeep now as well
grand Cherokee 5.9 V8
Old 16-08-2007 | 09:37 PM
Kevin Sharp
i,m fine mate just had a change of scene away from cossies the last year
this truck a big 4x4 or 6x6 thing then?....you should come offroading with us lot
you must have too much money if you can afford to fuel that cherokee as well
Old 16-08-2007 | 09:46 PM
StephenC's Avatar
StephenC
..BS Motorsport..
Thats the one and only downside with polycarb. At decent thickness it is indeed bulletproof, BUT, even rubbing your finger across it will cause fine scratches that cannot be removed. Perspex/acrylic is not as strong from an impact point of view but any scratches can be rubbed down with fine grit paper and buffed to a perfect shine again.
I used to work with clear plastics as a fabricator and hated polycarb, everything you do with it is horrible, forming it and welding it is so difficult as it bubbles and thats it.
If it was one deepish scratch that was bothering you it could with time and skill be removed with direct hot air but loads of surface imperfections and general discolouring is irreversable. If theyre flat panels it shouldnt be too costly to replace mate. There MAY be a meguirs product for it as I know they do loads for the plastics industry, we used a certain grade on acrylic and it realy was like magic.
Old 16-08-2007 | 10:57 PM
Luca's Avatar
Luca
Lukesville
you want to get some farcela plastic scratch remover comes in a toothpaste style tube and im pretty sure Demon tweeks sell it..
Give them a call or do a google search but you can definalty purchase it.
Plastic 4 performance recommended it to me works a treat.
Old 17-08-2007 | 09:51 AM
lardypants's Avatar
lardypants
yup they do the same stuff for polishing rear plastic windows on convertibles, i used a mop and some g3 before and that btrought up good results too
Old 17-08-2007 | 10:35 AM
Bomber's Avatar
Bomber
If you mop it - you will remove the UV layer protection on it.
Swings and roundabouts.
chowfornow
14
05-01-2019 10:01 PM
01-11-2015 07:53 PM
Mc5506
05-10-2015 10:57 PM
cossie330
27-09-2015 05:13 PM
caprixpack
25-09-2015 08:53 PM
Quick Reply: POLYCARBON WINDOWS, HOW TO POLISH??
