electrical advice
Old Aug 16, 2007 | 07:05 PM
turbo1973's Avatar
turbo1973
Default electrical advice
can any one help me im wiring up 2 down lights but not sure what to do with the earth wires it says in the instructons this unit is double insulated and must not be earthed if there are any incoming earth cables they must be joined together and well insulated with tape this is to ensure earth continuity throughout your property i have earth wires coming in but the lights are wired from each light into the main wires coming through roof what will i need to do
Old Aug 16, 2007 | 07:10 PM
Dave Parker's Avatar
Dave Parker
safely connect earth wires together in a connector of some kind and push up in ceiling away from heat of lamp fitting
NUTS RuS's Avatar
NUTS RuS
Tape the end up if there is only one
Old Aug 16, 2007 | 07:13 PM
turbo1973's Avatar
turbo1973
buti dont think i will manage to join them together because there wired apart and the roof been plastered
Old Aug 16, 2007 | 07:16 PM
NUTS RuS's Avatar
NUTS RuS
are they on the same ring - or a spur ?
Old Aug 16, 2007 | 07:20 PM
grsford's Avatar
grsford
are they on the same lighting circuit/switch
Old Aug 16, 2007 | 07:22 PM
turbo1973's Avatar
turbo1973
not sure what u mean they have wires coming from each light and are joined to the main wires that came trough the ceiling i have also lowered the ceiling
Old Aug 16, 2007 | 07:25 PM
turbo1973's Avatar
turbo1973
yes
KSA-Cossie's Avatar
KSA-Cossie
Stick it in a connector m8.
grsford's Avatar
grsford
how many lights were there before you done the ceiling and do they switch on together also is there only one cable at each light
Old Aug 16, 2007 | 07:27 PM
NUTS RuS's Avatar
NUTS RuS
Im not sure what your struggling with ?
You connect up the live and the neutral and just ignore the earths and tape/join them together for each light unit (treat as seperate units)
You not thinking you need to tape up each of your two units earths together are you ?
Old Aug 16, 2007 | 07:29 PM
turbo1973's Avatar
turbo1973
1 light and they switch on together
Old Aug 16, 2007 | 07:34 PM
turbo1973's Avatar
turbo1973
the live and neutrals are wired up lights are working but not sure what to do with the the earths it says join them to gether
Old Aug 16, 2007 | 07:35 PM
grsford's Avatar
grsford
if there is a single cable at each light and they switch on together then ther will be a jb in the roof or 2 switch lines at the switch where the earths should be connected to protect the cable put the earth into a connector at each fitting.
the light fitting should have a connector for the earth wire and there should be no visable single insulated wires outside of the down light connection box in the roof
hth
Old Aug 16, 2007 | 07:39 PM
rallyeweezle's Avatar
rallyeweezle
Im an electrician join the earths together in a connector block, dont forget to use earth sleeve. You need to make sure you have continuity otherwise the protective earth system will not work.
Any more Qus?
Dan
Old Aug 16, 2007 | 07:42 PM
turbo1973's Avatar
turbo1973
the light doesnt have an earth connection as its double insulated and must not be earthed if there are any incoming earth cables they must be joined together and be well insulated thats what it says in the instructions
Old Aug 16, 2007 | 07:43 PM
KSA-Cossie's Avatar
KSA-Cossie
He meant the cable feeding the light m8.
Old Aug 16, 2007 | 07:49 PM
turbo1973's Avatar
turbo1973
so will i need to buy earth cable and try and feed the cable through the holes to join the to earths together
Old Aug 16, 2007 | 08:00 PM
rallyeweezle
I guess one light is fed of the other.... join the two earths together where the feeds meet then just terminate the single earth on its own.
Dan
If you have anymore problems PM me your phone number and i will call you in the morning and explain it over the phone.
Old Aug 16, 2007 | 08:03 PM
KSA-Cossie's Avatar
KSA-Cossie
If there's one cable at each light then they've been jointed in the ceiling space somewhere,so just stick them in connectors m8.
Old Aug 16, 2007 | 08:27 PM
turbo1973's Avatar
turbo1973
sojust stick them in one of those clear blocks for each light and tape it up
Old Aug 16, 2007 | 10:58 PM
rallyeweezle
Sounds ok i think.
Old Aug 17, 2007 | 07:05 AM
turbo1973's Avatar
turbo1973
so do i do each light separate or do i need to get earth wire and join them together
Old Aug 17, 2007 | 07:29 AM
rallyeweezle
That’s the age-old question. The cable used to feel the lights should be what’s known as twin and earth.
External insulation will be either Grey or White.
old colours
Red = live
Black = neutral
No coloured insulation = earth
new colours
Brown = live
Blue = neutral
No coloured insulation = earth (cpc)
Old Aug 17, 2007 | 07:32 AM
turbo1973's Avatar
turbo1973
its the same as pic
Old Aug 17, 2007 | 07:34 AM
rallyeweezle
Ok the wire with no colour is earth.
Dan
Old Aug 17, 2007 | 07:38 AM
turbo1973's Avatar
turbo1973
i know that but what do i do with it
Old Aug 17, 2007 | 07:44 AM
rallyeweezle
Just connect the earths in the cable together, using a clear connector terminal. People used to just cut them off but we don’t do that anymore.
Dan
Old Aug 17, 2007 | 07:52 AM
grsford's Avatar
grsford
put some sleeving on it and then into a connector and tape up and if your still worried about it you will either need to have a earth loop impedence test done at each light or test for continuity from the earth at the switch or at the jb in the roof to see if you`ve got on earth at the light fitting.
hth
Old Aug 18, 2007 | 11:40 AM
turbo1973's Avatar
turbo1973
got it done thanks everyone that gave advice
Old Aug 18, 2007 | 11:43 AM
KSA-Cossie's Avatar
KSA-Cossie
Nice one m8.
Nov 1, 2015 06:53 PM
gcfcos
59
Oct 6, 2015 05:04 PM
stevecfrst1
Sep 30, 2015 05:18 AM
rsguy
44
Sep 29, 2015 03:29 PM
Marv888
Sep 26, 2015 03:44 PM
