update (gone to greys)
Took my car to torque of the devil a few weeks back and it made 295bhp with 320ftlb of torque with this set up, standard comp, greens, 3 bar, unknown chip, big cooler, t35 with .63, scorpion exhaust and group a filter, 22psi but the thing im asking about is what psi boost should i run the fueling was fine really rich top end but probably due to boost dropping off as the actuator was bolloxed it was opening at 5psi and they said it should of been 14psi so ive brought a new -34 and fitted that and also i read to remove the little white jet out of the amal valve on the atmosphere pipe to allow more boost, so what should i set it at psi wise ?
if you cant run much more boost depending on what your chip allows then i would suggest another chip which would do alot better job, Msd is your best bet as ive found there software is proberly the best ive worked with
Originally Posted by coswurv
Originally Posted by Stu @ M Developments
Only the mapper of the chip can answer that one mate.
well with the set up ive stated and a chip from msd what sort of power should i expect and what psi do you aim for on my set up ?
alright people, i have now upgraded to greys, i have one issue and it is that when im in 1st and 2nd gear and give it some it boosts and goes like hell but at the top end of the rev range it misses and drops power but i have noticed that the boost is still holding at 30 psi so i think i have to much pre load on the actuator holding to much boost in, also it did this when i had my greens etc in until i shut the plug gap up to 25 thou then it went away so maybe to much boost at high revs and shit plugs could cause this ?
TT T38 Power
Originally Posted by cossie4i
Get it set up before it blows up
Steve.
Steve.
Just turn the boost down and don't boot it about, let Karl sort it for you.
Steve.
Cake lover!
Steve.
Steve.
Steve.
Originally Posted by jay.
it could be over boosting ,nakerd amual valve , blowing the spark out , wireing issue ect ect ect
Guest
Posts: n/a
Originally Posted by Nash
coswurv Mine are gapped to .7 with Greys.
Why dont you leave it for Karl to sort and let someone who knows what thy're doing sort it out before it goes bang?
Gap the CORRECT spec plugs to around 0.6mm. If you need less you have ignition gremlins to sort as well, but go lower until you can sort them.
Thing is though, without your fuel checking out you dont know if your missfire is the only thing stopping your engine melting on boost, so take it easy until you get it sorted at Karl and Ollies.
Norris Motorsport
Hello coswurv,
Who's chip do you have in your car? i.e. who's car did I originally map that your chip has come out of?
I keep a record of everyone's car so I will be able to look back at my records and tell you exactly what spec and setup the car was running when mapped originally.
Hope that helps,
Hope that helps,
coswurv Stu's Ebay shop theres are the Plugs im running
http://cgi.ebay.co.uk/Rs-Turbo-Coswo...QQcmdZViewItem
I am still going to get a chip and bits off you stu BUT the car has had to take a back seat for now
jay.
You still ok to set mine up when i get around to getting the thing running
jay.
Originally Posted by Karl
Hello coswurv,
Hope that helps,
Hope that helps,
Well i gapped the plugs today to 20 thou and the missfire has gone pulls through nice, spikes to 30psi then holds about 28, but no more thrashing about for now, 044 pump and re-wire then off to nms, cheers guys for all your input much appreciated
