Garage Door Security.
Any suggestions?
I've had a quick nose on the tinternet and found this site: http://www.insurancesecurity.co.uk/s...security.shtml
I'm not sure whats best to use tho, i was thinking about one of those posts that pulls up out of the ground.....
Any thoughts? Or even feedback on what you use.....
If you decide to go for a post type thing, id put it inside the garage door so it doesnt draw attention to whats inside.
What sort of garage door do you have now? Roller shutter type or up and over?
had one of these infront of my parents up n over garage door, seemed to do the job nicely
search for Garage Defender on ebay
![](http://www.ringjunkies.co.uk/securi3.jpg)
bout 40 quid and easy to fit... simply rawl bolt the lower part of it to the floor, the top half padlocks through the bottom stopping the door being opened.
I cut a 1" square hole in the garage door at bottom centre, then used some 3/4" square bar, shaped like a "L" shape so it sticks up out of the floor(holes) 9" deep and then has an old fiesta rocker shaft, welded on end with end hole drilled out to accept padlock on it.
So this sticks up out of floor, remove when not needed then put back in hole close garage door so it goes through hole padlock through it job done, cost Ł2!!
I also cut some steel plate and made into squares to go around hole for reinforcing, either side of door.
Just have to bash a hole in the garge floor, that's all.
These seem quite good:
http://www.directlocks.co.uk/pacri-g...435fb853f1f961
They lock from inside or outside, good if you have a back door from garage to house
if you want security mate take a look at these,
mate has some fitted to his garage to protect his R1
http://www.bikesecure.co.uk/pages/ride_framed.html
cheers mark.
cheers mark.
![Banana](https://passionford.com/forum/images/smilies/banana_dance.gif)
On my old garage I only had the door lock and a padlock at the top showing,
Open the door and you had a pull up post and a bar going across locked on a post either side, was a nightmare to take the car out but it was safe and secure when it was in.
Any security showing on the outside means youve got something worthy of being pinched
they are neat and much easier to use the other locks/methods ive seen
expensive but do the job, the keys are cross shaped so doubt anyone would even try picking it
1K+ Super Poster!!
Originally Posted by BillyCabrio
Originally Posted by topaz
cheap and cheaful solution is to drill some holes in the runners and fit some padlocks
Originally Posted by Big G
Any security showing on the outside means youve got something worthy of being pinched ![Wink](https://passionford.com/forum/images/smilies/icon_wink.gif)
How about bolting some boss eyes into the concrete floor then properly chaning the car down - thru the wheels and over the rear axle?
CCTV has to be cheap enough to be considered now.
And don't nail the car up to the garage! Keep it quiet and subtle!
nipper.1
Ford KUGA
12
30-05-2022 07:39 PM
Mark V8
13-09-2015 09:34 AM
Adam Graham
06-09-2015 06:04 AM
