r888 flex / roll
right chaps
i have a set of r888's (235-40-17) for my s1 and they sit quite close to the springs on my coilovers
what i wanna know is do you get much movement in the tyres under cornering in them or the sidewalls quite rigid
i could space the front wheels out i guess if need be but for some reason i dont like the idea of using spacers (not sure why
thanks
gus
thanks
gus
shorter?
its the width?
i have no drive shafts in at the mo, so the wheels are pretty much doing what they want, just curious as to what i would have to play with
also the front end is fully adjustable so could have more or less room than i thought after being done
its the width?
Jeebus
With shorter springs the bottom spring cup will be above the tyre, thus creating more space
As a side not I have the spring cups set about 3mm away from my tyres on my 205. I've only used it with my road tyres so far but haven't noticed them hitting the springs/cups
07-10-2015 12:56 PM
