coilover help
Old Aug 12, 2007 | 03:35 PM
wide ka's Avatar
wide ka
Default coilover help
i have leda coilovers fitted to my ka, only thing is i want to raise the ride height at the front, now i have wound them up untill the spring is under tension when the shock is not underload, im i righ in thinking there is no point winding it anyfurther as it wont higher it anymore? so to make it higher i need different springs, or i differnt weight of spring, where could i get some from as leda went bust or how can i solve the issue, thanks alastair
Old Aug 12, 2007 | 03:36 PM
nilrem's Avatar
nilrem
STOP!... Carry on
so the shock is a its full extension, even when the car is on the ground wit hteh full weight on the sus??
Old Aug 12, 2007 | 03:42 PM
wide ka's Avatar
wide ka
no at full extension when there is no load on the shock, should i wind it further up till there is no travel when underload? but i would think it would be good to have some negative travel on the shocks?
Old Aug 12, 2007 | 03:44 PM
nilrem's Avatar
nilrem
STOP!... Carry on
i think there should be negative travel on shocks... but im not too sure...
surely it depends on how far the springs compress when under load...
Old Aug 12, 2007 | 03:56 PM
wide ka's Avatar
wide ka
thats the thing im not too sure!
Old Aug 12, 2007 | 04:24 PM
nilrem's Avatar
nilrem
STOP!... Carry on
only thing i can say is a bit of trial and error until you get to a "safe" medium... or wait until someone who knows about these things answers...
Old Aug 12, 2007 | 04:54 PM
wide ka's Avatar
wide ka
yeah good idea, so anyone else?
Old Aug 12, 2007 | 06:32 PM
Rich_w's Avatar
Rich_w
Proven Legendary Status
http://www.dfaulknersprings.co.uk/
They will make you any strength or length spring you want.
I beleive also the guys from Leda went and set up Gaz. But dont hold me to that.
Old Aug 12, 2007 | 09:12 PM
wide ka's Avatar
wide ka
anyone else got any ideas, also i presume i need to mesure the spring, just from top to bottom, or the i.d aswell?
Old Aug 12, 2007 | 09:47 PM
marco polo's Avatar
marco polo
hi
rally desings will make you any springs you need 2.25" what ever
any hieght any rating
pretty cheap aswell
marco
Old Aug 12, 2007 | 09:51 PM
wide ka's Avatar
wide ka
thnaks marco, when i ring they will want to know what weight i want, any idea what i would need, car weighs around the 800kg mark, or is there any way of finding out what the weight of my springs are?
Old Aug 12, 2007 | 09:59 PM
marco polo's Avatar
marco polo
hi mate
do you know the max and min bump and rebound speed of your leda's ?
Old Aug 12, 2007 | 10:01 PM
wide ka's Avatar
wide ka
no sorry got them second hand, the cars not on the road so i could remove the suspension with out any problems
Old Aug 12, 2007 | 10:02 PM
NUTS RuS's Avatar
NUTS RuS
Leda's are usually 2.5" ID springs depending on age of unit.
Wind it up more then see how it sits
Old Aug 12, 2007 | 10:06 PM
wide ka's Avatar
wide ka
carnt really tell though as there is no engine in it! ill try that tomorrow some time and report back
Old Aug 12, 2007 | 10:14 PM
marco polo's Avatar
marco polo
hi mate
i cant help you if you dont know , you cant really just put any poundage spring on them
what you dont want to do is put a hard spring on it and then the theres no damping thats the worse thing could happen
I have incresed my springs form 600lbs on the front to 750lbs but still has damping the max spring i can go without damping working is 990lbs
marco
my inserts rebound/bump 500/200
Old Aug 12, 2007 | 10:17 PM
wide ka's Avatar
wide ka
ill just see if i can wind them up anymore, dont really want to upset the balance between dampning and spring rate as ill prob make it worse, failing that ill just have to be carefull over speed bumps etc...
jessie_rs
62
Aug 6, 2019 09:27 PM
mk1turboestate
Dec 2, 2015 08:31 PM
S3an
Sep 26, 2015 11:39 PM
CrOwSoN15
Sep 24, 2015 01:36 PM
S3an
13
Sep 13, 2015 10:01 AM
