engine managment light?
Old Aug 10, 2007 | 03:14 PM
flat out's Avatar
flat out
Default engine managment light?
my mate has a vauxhall vectra and the eml is constantly on what is causing it? some of my mate's in the past have had vauxhalls and thay have had the same problem is it the ecu? and how do you sort it
thanks for looking
Old Aug 10, 2007 | 03:23 PM
ballin's Avatar
ballin
could be loads of things, need to get it plugged into a fault reader
Old Aug 10, 2007 | 03:42 PM
cozmeister's Avatar
cozmeister
More boost Igor!
He needs to get friendly with someone with a Tech2 then mate
Vauxhall charge over the odds for a 5 minute diagnostic session.
Old Aug 10, 2007 | 03:44 PM
bassboy's Avatar
bassboy
where are you based mate? what year is the vehicle? i have a diagnostic tester here
bassboy
Old Aug 10, 2007 | 06:03 PM
flat out's Avatar
flat out
bassboy
im from pontypridd south wales i only see my mate once in a blue moon so i wont see him for a while. i was just corious as a extra bit of knolage goes a long way and i might have a vauxhall again some day with the same problem. thanks for trying to help me out
Old Aug 10, 2007 | 06:18 PM
Madbradz's Avatar
Madbradz
www.vvoc.com
You can bridge connections to get the fault code you can find out how here.
Only needs to be plugged in if its a diesel
Old Aug 10, 2007 | 07:37 PM
philram's Avatar
philram
Mulechild
probably crank or cam sensor... there common faults, both cheap fix's
Old Aug 10, 2007 | 07:50 PM
Martyn's Avatar
Martyn
All you need to read the codes is a paperclip or short length of wire!
All info is here
http://www.vauxhallownersnetwork.co....ad.php?t=40464
Old Aug 10, 2007 | 09:18 PM
mad dog younge's Avatar
mad dog younge
get it plug in to a tech 2 at vauxhall any running problems with the car cos could b a number of things ps iam a vauxhall tech
Johnsie
Ford Focus ST
Sep 8, 2015 02:39 PM
Stu @ M Developments
41
Aug 21, 2015 06:47 AM
ar4ibaldo
Ford Focus ST
Aug 18, 2015 04:24 PM
Ben26
Ford Focus Diesel
Aug 18, 2015 03:42 PM
Old ford
Jul 31, 2015 06:50 AM
