Boot mounted Radiators
Old 24-12-2012 | 06:59 AM
  #201
graham c's Avatar
graham c
Thinner and wider would get rid of more heat if your like Andy escoz you would won't the others as his is going in both quarters
Old 24-12-2012 | 09:27 AM
  #202
black_jack's Avatar
black_jack
Black Jack
Originally Posted by hardasrs
this what i have come up with taken inspiration from G60rallye's stunning Audi, might not work but it will have two cold air inlets from rear side windows one each side and a scoop from under the car, then the hot air will exit via a big hole in the tailgate and two holes in the polycarbonate rear window, heat likes to rise so hoping when the car is stationary heat will escape through the rear window. the radiator will be enclosed.
the turbo is over the gearbox so thats not why i was thinking of moving the radiator to the boot, as the rs2k was not designed to have an intercooler fitted, so space up front is very limited for a decent sized intercooler, 100% want to try this but will use the standard engine to test first.
the rear of the car is at low pressure relative to the duct on top of the boot so the air would flow the reverse way to the arrow in that duct, bypassing the radiator when the car was at speed
Old 24-12-2012 | 07:07 PM
  #203
sierra1off's Avatar
sierra1off
I wouldnt have a duct from the tailgate window.
That area looks like it would be high pressure and would act against the air being scooped up from below.
The area that is deffinately low pressure it the back panel especially with the spoiler breaking up the airflow.
Its all about having a higher pressure one side of the rad more than the other
The greater the pressure difference, the more airflow and greater cooling
These are interesting
AutoSpeed - Undertrays, Spoiler & Bonnet Vents, Part 2
AutoSpeed - Blowing the Vortex, Part 1
Old 24-12-2012 | 10:54 PM
  #204
black_jack's Avatar
black_jack
Black Jack
Often the radiator was put in the back for weight distribution purposes -
eg - better traction/ weight distribution on a RWD mk1 / 2 Escort rally car or to help balance the front-heavy Audi quattro
As sierra1off has said - if the inlet is in a realatively high pressure area, and the outlet in a low pressure area - flow will occur - the highest pressure area is the front of the car (grill etc) everything else is medium/ in-between - the back panel is the lowest pressure area, as long as the exit is at the extreme back of the car, (eg, back panel) this low pressure area will "suck" the air through ducts of any shape or size on the top, bottom or sides of the car, with or without nrca ducts, big scoops etc
Because when the car moves through the air a low pressure area is formed at the rear of the car (realative to the top, bottom, or sides)
If the inlets are lower than the outlet/s, the the heat rises (a "chimny" effect) out of the outlet/s aiding cooling without fans even when the car is stationary, if this is the "wroing way round", it can cause problems or a reverse flow situation or this effect may work against the flow of the fan/s or the normal flow of the air when the car is moving
An electronically controlled electric waterpump does not need a thermostat, the temprature is controlled by switching the pump off/ on or turning it up/down automatically to reach a pre - determined (adjustable) temprature, the electric waterpump only works on demand/ proportional to need, and does not "rob" any power from the engine, the pump can be set to run after the engine is turned off and often the radiator fan/s can be dispensed with (saving weight- they only work under about 40mph in an efficiently vented system, anyway) it is more expensive than a mechanical pump but is more effective and is easier/ quicker to change - a lot of hot rods/ dragsters use them and some rally cars/ track cars - if i was building a rear mounted radiator - i would use an electric pump - i used one on my (front mounted radiator) project.
Old 25-12-2012 | 02:54 PM
  #205
graham c's Avatar
graham c
It also gets a lot of heat out of the engine bay which is a good thing
Old 25-12-2012 | 03:09 PM
  #206
Jay,'s Avatar
Jay,
Sponsor
Lol all this said by me and few others back in the post
But can be bad if you loos to much heat graham
Old 25-12-2012 | 04:17 PM
  #207
graham c's Avatar
graham c
You can just change the thermostat tho heat soak is a bad thing mine seems to run ok never had it on motor way tho
Old 17-08-2013 | 10:23 PM
  #208
Alg1k's Avatar
Alg1k
Old thread I know
I have done some more work on my rear rad conversion,
Im taking air from both sides of the car
I have made these air scoops out of carbon
They feed 2 inner air channels again in carbon to
Quite large air pipes into a air pressure box again carbon lol
Air will flow out the back HOPE fully lol
Still a lot of work to do but getting there
Good place to store the workmate fits perfect lol
Old 18-08-2013 | 10:02 PM
  #209
sierra1off's Avatar
sierra1off
Is the air exiting the rear panel or underneath ?
as the air under the car isnt normally very low pressure unless you have a deep spoiler at the front of the car keeping air from traveling underneath
That ducting looks good
Old 19-08-2013 | 06:24 AM
  #210
Alg1k's Avatar
Alg1k
It's not finnished yet but the air is leaving from just under the
Number plate ,
I have to make the duct for that yet
I have worked out the size it needs to be to
Have low pressure area as the air leaves the rad,
I'm going to be using a gopro camera and some wool tassels
To see what's going on,
I have tried to gas flow (Lol)the system to aid the air flow
The ducting was bstard to make !!! 3 piece mold ..
Old 21-09-2013 | 08:46 PM
  #211
Alg1k's Avatar
Alg1k
The air is leaving through this .
I hope LOL
Old 23-09-2013 | 08:29 AM
  #212
XRT_si's Avatar
XRT_si
That looks awesome!
Old 13-12-2014 | 10:38 AM
  #213
hardasrs's Avatar
hardasrs
quick question on the rallycross rear rad setups, have been looking at the newer mk7 fiestas, they all seem to have such a small air intake hole, outlet is only the number plate cut out, how are they achieving such good airflow,
Old 13-12-2014 | 04:13 PM
  #214
costina's Avatar
costina
Live long and prosper!!
Cos they spend most of their time sideways!!!!! A lot of cars have ducts in that area for cooling.
mark94
Ford Mondeo Including ST
10-10-2023 06:52 PM
tankybaby66
06-02-2016 02:24 PM
Quick Reply: Boot mounted Radiators
