Boot mounted Radiators
Old 11-08-2007, 04:13 PM
  #121
SillyFezzaMk1
Rubber Rhino Crew
SillyFezzaMk1's Avatar
Educate me then m8y...explain why i'm wrong.
Dan
Old 11-08-2007, 05:02 PM
  #122
GARETH T
GARETH T's Avatar
spoilers are designed for the most amount of downforce for the least amount of drag! in that in the drawing is an airbrake LOL
Old 11-08-2007, 05:05 PM
  #123
GARETH T
GARETH T's Avatar
Bomber
it sounds good in theory and it might work,,, but what you must do it take pressure readings from different points of your setup,,,, no pressure differential no FLOW
Old 11-08-2007, 05:21 PM
  #124
sbd16v
sbd16v's Avatar
that would totally depend on the car thou mate
on a mk2 astra or most cars with a rear bumper they have a bumper that goes down at the rear so aslong as you did not go lower than the bumper you would be providing the airflow a more slip stream route in that diagram that just hitting a brick wall of a rear bumper
Old 11-08-2007, 05:35 PM
  #125
sbd16v
sbd16v's Avatar
like this
the scoop would then provide a much better path than just hitting the rear bumper
Old 11-08-2007, 05:40 PM
  #126
GARETH T
GARETH T's Avatar
sbd16v
you quoted me out of context there,, i havent talked about rear bumpers
Old 11-08-2007, 05:46 PM
  #127
GARETH T
GARETH T's Avatar
i just realized that you on about the scope position and not my comment about spoilers
Old 11-08-2007, 05:49 PM
  #128
Phil
Jeebus
Phil's Avatar
how much drag would that induce
Have you seen the standard rear panel on a Mk1? It hangs down practically like that anyway, but with no where for the air to go at all!
Old 11-08-2007, 06:05 PM
  #129
GARETH T
GARETH T's Avatar
LOL,, i haven't noticed,,
Old 11-08-2007, 06:08 PM
  #130
Charlie Chalk
Unknown.
Charlie Chalk's Avatar
sbd16v
He's comparing, The drag your on about with the tunnel under the car would be like, if not the same as what the bumper does anyway
Surely the tunnel would be better?!
Old 11-08-2007, 10:29 PM
  #131
sbd16v
sbd16v's Avatar
yeh sorry mate was more about you saying it was a air brake where if you had that on a car like my mk2 astra it might actualy help
Old 13-08-2007, 07:55 AM
  #132
Luca
Lukesville
Luca's Avatar
Bomber
thats looking good and should work well, im thinking though the rad could work better laying down however as the flow will be greater through the rad.
Then it comes down to getting rid of the air. I think in a mk1 fiesta and mk3 you would then need to use the rear tailgate.
Im of tonight to a mates who has funnily enough decided to do the same
Not spoke in a year but caught up last week, he has a Golf Mk2 runnign a 20v T engine and a boot mounted rad he has brought the air in from behind the driver/passenger seat using a fibreglass ducting arangment then the air flows out the boot lid.
Il try and get some pics of this,
Still no news from the Norweigans, they dont want us Brits stealing there ideas i think.... lol
I spoke with Alex who lives overthere and he has kindly posted this thread on a few forums overthere, hopefully we have some luck soon
Old 13-08-2007, 08:03 AM
  #133
vibrating_cake
vibrating_cake's Avatar
what MIGHT help, just as a thought is partitioning the ducts off with thin walls, this helps direct the air in a streight line through the enclosure, helping direct it from entrance to exit, rather than entrance, spinning around in the low pressure area around the rad and eventually being pulled out.
they were banned in an american race sieres on diffusers so im guessing they actually work, saves on sidewards turbulance gives it more of a "tunnel" to run through
Old 13-08-2007, 09:25 AM
  #134
Ken_ZS
Ken_ZS's Avatar
might b worth u guys lookin up VW campers wiv scooby lumps in, these guys normally raise the floor a little mountin the rad flat (like ur design pics) with a metal pan underneath extendin forwards to scoop air in, only easy part these guys have is a open engine bay behind the rad! anyways take a look about cos they might turn up some good tips
Old 18-08-2007, 10:19 PM
  #135
SillyFezzaMk1
Rubber Rhino Crew
You dont get free downforce m8, the downforce comes at a price...i.e. drag due to having to deflect the air to gain downforce...if you positioned the ducts in a certain way you could create downforce from a rear mounted rad setup.
Old 19-08-2007, 02:22 AM
  #136
GARETH T
GARETH T's Avatar
its a balancing act mate downforce ISNT directly proportional to drag
Old 20-08-2007, 02:40 AM
  #137
Benni
Ban[B][/B]ned
Benni's Avatar
BTTT!
Old 20-08-2007, 08:28 AM
  #138
Luca
Lukesville
Luca's Avatar
Still on the case but its taking time.....
have contacted few people from Gatebil via email and eagerly awaiting a response
Old 20-08-2007, 09:15 AM
  #139
Bomber
Bomber's Avatar
Nothing much changed on my side of things... I tried to get motivated to sort it out this weekend ... But i just couldnt be bothered!
Old 20-08-2007, 03:32 PM
  #140
foreigneRS
Testing the future
foreigneRS's Avatar
i looked at the silver gatebil escort cosworth on saturday and can't see it working very well
the only way in for the air that i could see was 2 NACA ducts in the rear windows with flaps behind to get more air in the duct - but the ducts were not connected to anything but the air would be sucked out of the bottom of the car and through the radiator if there is enough pressure difference
he went out a couple of times, but not for long until towards the end of the day when he put on a mental display
Old 20-08-2007, 03:39 PM
  #141
Luca
Lukesville
Luca's Avatar
I was wondering if Leif’s car had temp issues as from the Feature of Gatebil in Fast Ford the car has no rear quarter windows, so im thinking he is having temp issues when out on track.
From photos I have seen of this car I cant see either how air is directed through the rad other than those window vents.
This may explain why as yet I have not had a response from anyone – as the problems are not solved as yet on this.
Old 17-11-2008, 09:39 AM
  #142
Mike C
The Special One
Mike C's Avatar
Did anyone ever find out more/go further down this road?
This is something I really want to do now, but still not sure how to get through the air flow situation.
Sure, run ducts through the rear windows, but how do I let air in/out through the rear?
I could create a hole in the boot floor, but would the hot exhausts running near it create a problem?
And how do I let air out through the rear without cutting unsightly holes in the back of the car?
I was going to create a rear diffuser anyway, and I could have a slim vented area at the top of it as per the F430 picture earlier in this thread, but surely that wouldn't be enough would it?
I could also cut out holes behind the number plate and then drill vent holes into the plate itself like on the front of that MK4 Escort in Redline this month, but would that be enough?
Also, what about fans?
And how would this set-up affect the car when stationery for long periods in traffic?
Lots to consider
Old 24-03-2010, 08:11 PM
  #143
sierra1off
sierra1off's Avatar
Did anyone get their rear rad install finnished ??
Old 24-03-2010, 08:15 PM
  #144
robp-tt
ZETEC TURBO
robp-tt's Avatar
bomber didnt fit his in the boot of his fiesta in the end, he kept it upfront
Old 23-04-2011, 04:34 PM
  #145
graham c
graham c's Avatar
any one got any nearer with this as am looking in to it to
Old 23-04-2011, 05:24 PM
  #146
Mint FRST
Mint FRST's Avatar
This guy has done it IIRC...
http://www.s2forum.com/forum/showthread.php?t=26537
Awesome thread also!
Old 23-04-2011, 05:38 PM
  #147
graham c
graham c's Avatar
he,s more nuts than me
Old 23-04-2011, 08:25 PM
  #148
G60rallye
G60rallye's Avatar
Thats my car, not tested it out yet so it might not work!
I dont see why it wont work though. I wouldn't have much faith it the ones that draw air through small vents in the windows etc.
Old 23-04-2011, 09:36 PM
  #149
Mint FRST
Mint FRST's Avatar
Sorry mate, didnt realise you were a member...
Old 23-04-2011, 10:21 PM
  #150
G60rallye
G60rallye's Avatar
No problem at all. I dont post much on here I just like reading through, theres lots of great information to be found on this place!
Old 24-04-2011, 08:07 AM
  #151
graham c
graham c's Avatar
i think that will work fine
Old 24-04-2011, 08:39 AM
  #152
cossie.con
cossie.con's Avatar
Default Few ideas here
http://www.flickr.com/photos/johnsidc/2503604220/
http://www.google.co.uk/imgres?imgur...2/18082220_640.
http://www.aetturbosonline.co.uk/ind...d=36&Itemid=63
Old 15-07-2011, 09:14 PM
  #153
graham c
graham c's Avatar
well ive done mine so i hope it works ok
Old 23-12-2011, 10:42 PM
  #154
bunnymofo
bunnymofo's Avatar
dose it work ?
Old 24-12-2011, 06:11 PM
  #155
Grantcos
Grantcos's Avatar
Could you put scopes in the rear quarters and have a honda civic rad at each side of the car, thse are compact and effecient.
It could be like MR2's where the air enters a scoop to cool the intercooler, but you would have a rad on each side linked with piping, then have some cowls to point the airflow towards the bootlid where it would be vented to allow the hot air out of the car.
Just use a smart design and not a gay mr2 scoop!
Old 24-12-2011, 06:19 PM
  #156
graham c
graham c's Avatar
mine seems to work fine
Old 24-12-2011, 06:22 PM
  #157
gouch1
gouch1's Avatar
Originally Posted by prius
better to have the engine in the back and the radiator in the front along with the shopping
+1
Old 24-12-2011, 06:26 PM
  #158
Mark_
Mark_'s Avatar
wouldnt it be possible to cut a radiator sized hole in the boot floor and mount the radiator lower than the boot floor and make a duct to aim natural airflow towards the rad and then box it in in the boot?
Old 24-12-2011, 07:54 PM
  #159
graham c
graham c's Avatar
yes mine is in the boot on a angle with big holes in my boot lid
Old 24-12-2011, 08:33 PM
  #160
Mark_
Mark_'s Avatar
I was thinking of ducting the air from under the car onto the rad through the boot floor?
Quick Reply: Boot mounted Radiators
