Mk3 escort rear disc conversion...whats needed ??
Can anyone tell me exactly what i need for converting my rear brakes to discs on my mk3 escort ??
I know you need cossie rear calipers and a Mk5 RS 2000 handbrake cable but what exact other parts are needed ?
Mounting brackets, spacers etc etc!!
Cheers guys.
Cheers guys.
Irritating c........
Only worth doing when you have upped the front brakes sufficiently, as with standard front stoppers, you;d end up having to fit a bias vale to bleed off the rears enough to stop it wanting to swap ends when you anchor up..... So unless you go big discs and calipers upfront (ie, Cossy conversion, or aftermarket kit) it ain't worth doing - unless you only want to do it for looks, which is a bit daft really.......
hi
hi guys i have an orion mk1 (escort mk3) i have bought a full kit of rear disc conversion and also cosworth calipers for front. The rear have everything but what do i need more for the front please? of course the discs but what size? i have 17 inch wheels on the car. Thanks
Ha ha, This was asked way back in the day when i was doing up the XR3 !!
Still got the capri Lee mate, should have some paint in the engine bay this weekend so can start to make some progress fitting the 24v lump then Aint bothered to update the resto thread i started as not much interest in the old capri's these days
I've not yet come across the new clips and bits and pieces i had bought for the escort that i said i would send on to you, got boxes of parts still up in the loft to try and sort through so will find them eventually, will send them out to you whenever i find them ! Car starting to look good now and your making good progress, always good to be bolting parts back on rather than taking off aint it !!
track.focus'd
12-08-2015 05:53 PM
Graceland
31-07-2015 10:34 AM
