RBmotorsport rear shims, worth fitting
http://www.randbmotorsport.co.uk/shop/Parts.asp?ID=5
is it worth fitting a set of these?
going to fit bayjoo springs & deflex bushes to my saff, already got adj TCA's up front
would i benefit fitting these rear shims as well whilst im at it
will it improve grip/handling?
Team HOTHOT!
Definately worth fitting - My car felt less twitchy in a stright line at high speed and the turn in was slightly improved aswell.
Took me 30 mins a side to fit them
Originally Posted by DaBoy12s
what do these do? i am guessing they correct the geometry on a lowered car?
Sure someone will confirm!
Caraholic
Caraholic
Originally Posted by RWD_cossie_wil
why cant you fit an extra bit of shim on the top forward bolt as well? just to play with the camber a bit as well as the toe?
I have 2 sets I have yet to fit
*DO NOT DO THIS! It gives horrendous handling trates - the car feels like the back is pitching into the corners .
Worth fitting, but toe and camber needs checking before and after fitment.
to make sure the beams staight at the start, and the shim's have done the job intended.
I think i might be needing a set of these......mine feels like it pitches itself into corners without any shims!!!
Back end skips around under braking for corners!!!!
Originally Posted by Moonstone Steve
I was told i have these fitted on my magenta saph (perhaps Rhys can confirm this) it does feel better than my moonstone saph though.
Steve.
Steve.
Steve.
Steve.
Steve.
Monte Geek
I fitted mine today (had them over a year ) didn't try any high speed bends but the turn in deffinalty felt improved on mini roundabouts and the rear end felt a little more settled, will let you know more after a longer and faster drive
Got some fitting pics on my thread
track.focus'd
12-08-2015 05:53 PM
Red_bull
09-08-2015 08:34 AM
