MSD's ALS feature in Fast Ford
Old 06-08-2007, 10:50 PM
  #361
Benni
Ban[B][/B]ned
Benni's Avatar
Originally Posted by Redkop
Originally Posted by markk
Originally Posted by 68332
I suppose it depends how much the RPM drops once you have changed
from one gear to another.
So you could say the "lag" is dependant on gearbox type/ratios etc ... another factor
a pretty MAJOR factor i would say, but then how many people have experiance on close ratio gearboxes in turbocharged cars ?
Me
And me, I used to own a diesel. LOL! Now I am talking diesel can a diesel have ALS?
Old 06-08-2007, 10:54 PM
  #362
Chip
*** Sierra RS Custard ***
Chip's Avatar
Me
you are saying your diesel (as in the low revving engiens that have wide gears) had a close ratio box?
all diesels have an ALS bypass fitted as standard, its called no throttle, lol
Old 08-08-2007, 10:12 AM
  #363
Benni
Ban[B][/B]ned
Benni's Avatar
Me
I got confused with Ratio and RPM! Do you see where I got confused?
Old 08-08-2007, 10:17 AM
  #364
Chip
Chip's Avatar
You got confused at the point where you havent got a fucking clue what you are talking about and should leave interesting threads to the grown ups?
Old 08-08-2007, 10:19 AM
  #365
Benni
Ban[B][/B]ned
Benni's Avatar
You won't learn if you don't join in.
Old 08-08-2007, 10:35 AM
  #366
Chip
Chip's Avatar
You will if you just read and try and understand.
You wont if you dive in and spout bollocks and drag the thread down
Old 08-08-2007, 10:43 AM
  #367
Benni
Ban[B][/B]ned
Benni's Avatar
Dragged the thread down? It was already on it's arse to begin with. I wasn't spouting bollocks I was joking about the Diesel comment hence the LOL and smilie. And if I had of said nothing I wouldn't know what I now know which is close ratio and Short rev range are different.
Old 08-08-2007, 12:23 PM
  #368
CossieRich
Did Someone Mention TUV
CossieRich's Avatar
Fucking hell Chip mate. Back off a bit. He doesnt understand, no need to make him feel bad. I know he "hangs" in the muppet room most of the time, but hes only showing an interest.
Old 08-08-2007, 12:27 PM
  #369
Chip
Chip's Avatar
Anyone giving it large with a symbol while trying to look clever is fair game IMHO
Old 08-08-2007, 12:30 PM
  #370
CossieRich
CossieRich's Avatar
Fair enough.
Benni, back to the muppet room
Old 08-08-2007, 04:28 PM
  #371
Benni
Ban[B][/B]ned
Benni's Avatar
Fair enough.
You have to try and look clever around here or you won't make any friends. Anyway I tried and I failed so I'm going back to the muppet room now!
Benni.
Old 08-08-2007, 04:31 PM
  #372
Dan Cossie
Dan Cossie's Avatar
Fair enough.
Pair of bullies
Old 09-08-2007, 12:06 PM
  #373
dojj
Resident Wrestling Legend
dojj's Avatar
Benni
deiseals only rev to 5k so they need to have an engine that is flexiable throughout the whole rev range and longer gears to keep up with the petrol engined counterparts which can rev to at least 20% higher, in some cases you'll get 9K out of a honda engine yet a fair amount of deisesels will run out of puff coming up to 4.5k
there is also the thing about variable van turbos but tha'ts touching on a subject that doesn't really relate to this topic, unless there are plans afoot to make a range of variable vane turbos' for cossie applications that will also run als/lc
the problem with variable vanes (apparently) is that you can't dissasemble them because they work in a complcated way
so, back on topic
Old 09-08-2007, 12:09 PM
  #374
Benni
Ban[B][/B]ned
Benni's Avatar
dojj Cheers mate, Much appreciated.
Old 09-08-2007, 12:19 PM
  #375
carlo
carlo's Avatar
Old 09-08-2007, 01:32 PM
  #376
dojj
dojj's Avatar
now all we need to have is someone who can put anti lag/launch control into the same sort of 2 line description and job done
Old 09-08-2007, 02:36 PM
  #377
foreigneRS
Testing the future
foreigneRS's Avatar
so, back on topic
not at all - the problem is the mechanism cannot stand the higher combustion temperatures of a petrol engine compared to a diesel (except that the latest porsche 911 has them fitted, so those problems must have been overcome to some extent)
anyway, back on topic - although i think it died a while ago
Old 09-08-2007, 03:56 PM
  #378
dojj
dojj's Avatar
so, back on topic
for benni's benifit, poches are more expensive than normal cars and so they can have expensive bits fitted on them that bend the rules a little
steerfromdarear
28
29-01-2016 06:14 PM
Billy_RS
15
05-09-2015 12:04 PM
TommysKeeper
13
14-08-2015 08:22 PM
Versus_Creations
20
08-08-2015 10:22 AM
Quick Reply: MSD's ALS feature in Fast Ford
