512Mb Memory Stick....
Ive just bought a 512mb memory card for my phone, i put it in and it says 452mb? Seems a bit strange? Do they all have less than stated?
More boost Igor!
The capacity shown on memory sticks and hard disks is always less than what they state. Has been from the beginning of time
This is due to some of the space being reserved for the File Allocation Table (or whatever the device uses as an equivalent), and for the disk's layout.
Imagine taking a football field, and having to divide it up into 6, but having very clearly defined boundaries for those 6 so that no-one can miss the gaps.
The football field has an area of X square metres. Some of that area goes missing to allow, for example, a 1 metre wide walkway/gap between the 6 areas - the same thing with memory sticks and hard disks so that they can find the information you've asked for.
They also reserve a (relatively) small amount to hide bad sectors should they develop.
Fast Ford snapper
Its a bloody rip off... I recently bought a 500GB hard drive and it came up as having something like 430GB avaiable!
I know why it does this but why not just call it a 430GB drive if that's all I'm ever going to be able to use of it?!
More boost Igor!
Because in the very small print it says xGB unformatted, so when it leave the factory, blank, it can hold xGB of data. The problem is that some of it isn't available to the end user but is used by the drive, ergo it's a xGB drive. Gotta love loopholes, eh?
And, different filing systems have different overheads, so if you formatted it with NTFS, you'd have a different usable capacity to FAT32, for example.
From a marketing point of view, manufacturers assume the average Joe won't know the difference and the higher the number and lower the price the more value Joe thinks he gets for his money. On average you'll lose between 10 and 15 percent of the unformatted capacity to the filing system and disk layout.
DAN@ADRIAN FLUX
37
20-09-2015 10:38 AM
soulweavers
Computers, Consoles and I.T.
01-08-2004 09:03 AM
