will a xr 4x4 box fit straight into my cossy-any differences
The gear box in my saff has died and ive been offered a xr 4x4 box, just wondered if it will fit and if anything need swopping over, any help much appreciated, cheers matt
i'm getting mixed up here.
what do you change to the 4x4 cossies to get the different ratios.
thought you used the step off gears in the 4x4 bos and the rear diff.....if so....what car are they from.
i thought they were off a 2.0 twin cam 4x4.
or have i had a drink or two two much.
dave cos4x4
the gearboxes are exactly the same bar rwd mt75s
the diff ratios is where your getting confused
when you use a 3.9 in the rear of a cosworth if you dont change teh front aswell you will have to have a setp off gear in the transfer box to comensate to make the difference up as you will be running 2 different diff ratios
Resident Wrestling Legend
the normal rwd ratio's are 3.92:1 or 3.64:1
the 4wd cars use a 3.92:1 on the dohc cars only, be they badged xr or ghia
the rest of the range used a 3.62:1 diff front and rear
BUT
even though the 2.8 sierra's used the same ratio's, you cannot retro fit the 2.8 front diff onto the other 3 sorts of sumps (2.0 twinky, 2.0 cossy or 2.9 12V V6) because it's different and don't fit, even though some peole will tell you that it does
BUT
matman
09-09-2015 05:45 PM
