cossie stage 3 glitch ideas needed
gents
on stage 3 esco, 3 bar, dark greens,t34.48, group A pump
got a glitch in 1st and 2nd gear a very slight missfire around 3800rpm
not always but sometimes, its a big miss and a backfire, and car totally judders etc then takes off
ive just fitted a new engine and it wasnt doin this before
have got new plugs, leads and distributor cap/rotor on order
are plugs getting blown out ? tried two sets still same ?
or whats goin on ? mixture wrong ? its running rich i think exhaust is sooty
any ideas
any ideas
I,m no expert but i,d check the Phase Sensor gap is right and check the two wires running to it inside the dizzy as these can corode and short out !
071 c motorcrafts also tried champions, both same.
standard leads, ive just ordered some tailor made ones from a rally guy
not suggesting running rich would cause it lads, just trying to give info that may help
thanks for the comment re phase sensor, does anyone know the correct gap lads ?
will check that out fully tmrw
Originally Posted by neil d
how much boost ? usually plugs but only over 20 psi was mine doing it
shes hitting 1.6-1.8 around about there mate about 4000 ish i think
Originally Posted by Spiky
put some NGK9's init
what gap you got on your plugs at the moment????
tried some with a big gap and some with a small gap
i dont have tools that hi tech mate
champion c57c s sorted mine they dont last to long though .you got a group a coil bigman ?they seem to rave on about those ngk 9 s but are top money
cool mate i aint sure about the coil, i saw those plugs at the shop today 3000miles and they need changing
ive ordered some Ł12 each ngk's instead should do the trick it must be blow out because boost only seems to spike high in 1st and second
hope that will sort it
cheers mate
i wouldn't hold a car out full on c57's
ngk 9's are more expensive, but last soooooooooooooooooooooooo long
Originally Posted by Rs Gus
mine runs 071's with 35psi peak and 28held no probs may bee ya phase sensor/cranksensor
checked crank pickups etc seemed ok
just finding my feet
im getting it set up soon anyway so ill let steve at SCC sort it out
got the boost issue sorted so my work on cossies is done
the next mod im gonna do to the car will be changing to oil
impreza wrx sti version 8
Originally Posted by Jano_OddKidd
Any joy yet?
It may be a sensor. If you are close i can connect the engine to Diagnostics equipment to check your system and other areas that could cause the problem.
Regards
Jano
Regards
Jano
will run through the suggestions given in this post tmrw and hopefully will trace something that sorts it, could well be phase sensor gap etc
big_Rad
15-09-2017 09:36 AM
rog
04-09-2015 12:10 PM
CabrioTurbo
01-08-2015 11:04 AM
