cossie problem help needed
Old Jul 19, 2007 | 07:39 PM
tregmatt's Avatar
tregmatt
Default cossie problem help needed
Does anyone know what this is..
I took the cossie out 2 day everything was fine with no problem's then when i started to put my foot down it started to pop and fart and wont pull over 3000 rpm.
On tick over its lumpy and its puffing out black smoke on tick over and when you rev it.
its also got a very strong smell of petrol.
It's lumpy when it revs but when you rev over 3000rpm its fine. but if i drive it over 3000rpm its missing and wont have no boost and need to take your foot off.
has anyone else had the same problem or help with what to look out for.
thank's
Old Jul 19, 2007 | 08:08 PM
JTECH James's Avatar
JTECH James
Passion for Fords!
check you havent blown a pipe off like a fuel reg pipe, or split/leaking
Old Jul 19, 2007 | 08:11 PM
Eagle's Avatar
Eagle
Super Moderator
map sensor???
Old Jul 19, 2007 | 08:17 PM
abdr500's Avatar
abdr500
map sensor or the tps or the blue sensor at the back of the head it will cause this problem
Old Jul 19, 2007 | 08:37 PM
tregmatt's Avatar
tregmatt
where would the tps sensor be located and how could u tell
thank's
Old Jul 19, 2007 | 08:40 PM
Eagle's Avatar
Eagle
Super Moderator
tps is sat on the side of the throttle body with the acelerator cable attached to it ..
Old Jul 19, 2007 | 08:42 PM
tregmatt's Avatar
tregmatt
how will i know if its not working.
would i need to try a new one or just clean it
thanks
Old Jul 19, 2007 | 08:43 PM
JTECH James
Passion for Fords!
the cable doesnt atach TO the tps, its the other side of the throttle body
Old Jul 19, 2007 | 08:44 PM
JTECH James
Passion for Fords!
have you got a secs monitor? ideally you need to check the throttle sweep/voltage
Old Jul 19, 2007 | 08:46 PM
tregmatt's Avatar
tregmatt
i haven not got one at the momet but thats the next things im going to fit.
the car has been find and it only started 2 do it 2 day.
its smells of fuel really really bad
Old Jul 19, 2007 | 08:47 PM
Eagle's Avatar
Eagle
Super Moderator
you know what i meant
Old Jul 19, 2007 | 08:48 PM
Eagle's Avatar
Eagle
Super Moderator
i still think its the map sensor ...mine did exactly the same at national day last year..
Old Jul 19, 2007 | 09:06 PM
tregmatt's Avatar
tregmatt
will i have 2 change it 2 find out if its that id so il have 2 borrow 1 2 try
Old Jul 19, 2007 | 09:14 PM
xr4x4rs's Avatar
xr4x4rs
check the pipe on teh map sensor aswell make sure it hasnt come off
Old Jul 19, 2007 | 09:22 PM
tregmatt's Avatar
tregmatt
the pipe is still on but i dont know how u can test the map sensor or is it only by changing it.
Old Jul 19, 2007 | 09:35 PM
Spiky's Avatar
Spiky
defo sounds like the map sensor dude,
I would NOT drive it, until fixed.
find someone to lend you their's, then if it is, buy a new oine job done
again DONT DRIVE IT NO MORE
Old Jul 19, 2007 | 09:38 PM
tregmatt's Avatar
tregmatt
cheers spike i hope thats all it is.
Old Jul 19, 2007 | 10:09 PM
Dicko&Vacant's Avatar
Dicko&Vacant
mine done exactly the same thing mate and it was map sensor have you got a standard one just to try?
Old Jul 19, 2007 | 10:13 PM
Doug's Avatar
Doug
Map sensor I also had this fault prob got water ingress .
Regards Doug .
tregmatt's Avatar
tregmatt
i will c if i can get hold of one 2moreow 2 c if it is,
if i try a new 1 will it clear strait away if it is that
thanks
Old Jul 19, 2007 | 10:15 PM
Spiky's Avatar
Spiky
yeah instantly
Old Jul 19, 2007 | 10:16 PM
Doug's Avatar
Doug
Originally Posted by Spiky
yeah instantly
What she said !
alright spike u ole slapper
Regards Doug .
Old Jul 19, 2007 | 10:17 PM
tregmatt's Avatar
tregmatt
money well spent then if it work's. the map sensor has been on there a bit now so i hope it is that.
will let u know
thanks
Old Jul 19, 2007 | 10:37 PM
Spiky's Avatar
Spiky
yeah instantly
What she said !
Regards Doug .
hi gimp
where you living now? as i cant keep up
what toy you got now???
Old Jul 19, 2007 | 10:51 PM
NEEDFORSPEED's Avatar
NEEDFORSPEED
sounds like map but can check tps with multimeter as if you were setting it up
Old Jul 20, 2007 | 03:41 PM
tregmatt's Avatar
tregmatt
yes it was the map sensor thanks for all you help its all sorted know i know what it is. thanks to paul 3 door rally slag for a lend of one and the tools nice one paul
Old Jul 20, 2007 | 05:27 PM
Eagle's Avatar
Eagle
Super Moderator
bloody eck .. i was right
glad you got it sorted mate ..
Old Jul 22, 2007 | 06:13 PM
tracktoy's Avatar
tracktoy
no problem dude
carlo
24
Oct 5, 2015 08:20 PM
kosienutter
31
Aug 22, 2015 09:55 AM
Stu @ M Developments
41
Aug 21, 2015 06:47 AM
col93saphcos
Aug 7, 2015 03:21 PM
wheelwizardrefurbs
Aug 4, 2015 06:23 PM
