Slicks Compared To Road Tyres
Yoon
Could be an interesting thread........
I was wondering what's the main components between bald road tyres and slicks.
I understand that if road tyres are worn and become bald the grip level deterioates vastly.
Yet, why is it that slicks are bald to look at and provide vastly superior grip?
Is it because to get that 'sticky-ness' and grip out of them you have to warm them up a fair amount? What would happen if you put some tyre warmers on a pair of bald, worn road tyres?
I am fairly new to tyres and the principles behind them and could do with some in-lightment.
Its down to how the tyre is made, its construction.
When worn out a road tyre is has about 2-3mm between the road and inside of the tyre
Remember any tyre with thread has it for one reason - to shift water out the way!!
Alex
Alex
Super Moderator
driving on slicks is a totally different experience to any road tyre ever the best do not touch the performance of a slick,as to putting tyre warmers on a bald road tyre it would make it even worse as it would over heat
if you look at the history of track days why people crash insated of making there car handle and stop and fit proper tyres they over heat road tyres and hit the pit wall or end up in the kitty litter
Take your average fast road car add a set of slicks and then go around the track,you will see and also feel the difference
STOP!... Carry on
different compounds help aswell...
slicks work on the basis that as much of the tyre is on the road as it can be... where as road tyres have to work in all conditions, as well as a much longer time... thats why they have tread patterns and are usually a harder compound, to remove water (las was said above) and how would you feel if once a week you had to change your tyres?
thats what i learnt in my a-levels anyhoo...
Yoon
Thanks for the replys guys.
Looked into in some more and have come to the following points:
1: Slicks are made of a much softer rubber then road tyres so once warmed up provide a much more sticky contact area to the road then a hard, cold road tyre.
2: As they don't have all the groves on the tread like Alex said, they have a larger contact area as well as the above contributiing factor.
3: Also as Nilrem said, they are made of a much more higher end rubber and don't have to last ten thousand miles under all condtions like a normal road car tyre. Similar idea applies to using them in the wet as well I gather.
Another quick question though, why would normal road tyres overheat if tyre warmers were used? Is it because they aren't upto the the temperature loadings? I only used the warmers on balk tyres as a case point, I wouldn't do it in reality.
And remember there are good slicks and bad slicks too just the same as there are good and bad road tyres.
For your last question - the rubber has an operating temperature range.
Stay inside this and your fine, veer out of it on either side and it can be like driving on ice
First time on slicks back in 2000, and on the first lap, a little too much entry speed on the corner, and it understeered off the circuit like I was driving down an icy hill!
Warmed up to operating temperature, and the grip levels are astounding compared to road tyres.
Not all Basky,
Some slicks on racing cars have virtually NO sidewall construction at all and would be dangerous on a heavy road car. Strength in them is determined by the tyre pressure. Racing cars don't roll or lean on them as much in the corners as a saloon car would. Put a set of these on and your in Pons kitty litter too
