Air charge temps
I had 50 deg at the end of the runway doing 185.
Pro alloy running 35 psi in a cold day in November.
Havent had a chance to to do any testing on the road.
new cooler keeps temps down under 40 on the rollers
Its how the cooler holds up on long high speed runs that shows how its performing.
i agree.
i use my brakes in 3rd gear to get the ACT's higher than normal, then release the brakes and go thro to full speed.
This will show ACT's go 50oC+ and then the intercooler bringing the temp down, and then it will sastain (sp) a set ACT's.
On every car i do this, the results are always the same.
Mine runs 28-32 Dec.C Normally even when giving it beans. Never seen it above 40 Deg!
I've always said AH Intercoolers are the bollocks, yet they always get overlooked by 'prettier' rivals.
Ah cooler seems to perform a bit better than my normal pro alloy one then?
I know its not as cut and shut as that but you know what i mean.
i think so, it did do better in the PF feature (even tho not really a good test.
the only real way of telling is a Proper/accurate test on 1 car.
i've got a new setup comin in 2 days, with alot better end tank design, and a newer designed core (same size).
My old one is 3 years old, and i designed the end tanks to fit the car, but this time i'm making the car fit the inter.
i have to admit, its not spit polish finish, but as you say it performs 100%, and still nice to look at.
I believe Alex was the first to get a 500 intercooler Right, and the rest just looked and followed.
how old your cooler?
Mark RS
12-10-2015 06:01 AM
Johnny Knoxville
30-09-2015 07:21 AM
Russ Payne
25-09-2015 08:29 PM
