testing a cosworth loom?
when testing a cosworth loom for resistance/ohms should the reading be constant or flashed up then gone?ie map sensor input 4.6 constantly there, map sensor output 1900 flashes up then dissapears,then i have to wait 20 seconds or so before it will flash the reading again,is this correct?
are you just testing end to end resistance? If so it shuold be constant and very low (even 4ohm seems high to be honest). If its flashing 1900+ up every now and again your probably measuring the resistance of your body!
ekjim
17-08-2015 08:57 PM
muz
16-08-2015 12:57 PM
