Stable vacume reading on carb per cyl?
I have just bought a mega jolt mappable ignition system for my carbed zetec
It has a map sensor built in and was wondering having 4 carbs, thus 4 vacume pipes, If I link all these together will I get a stable enough reading?
Or should I pipe them into some sort or accumulator / mini chamber like a soda stream bottle, to try and dampen the pulses
Cheers Bri.
Cheers Bri.
I could tell you.... but I don't recall selling it to you
Oh alright...
Interconnecting the cylinders is a good idea - as is restircting the diameter of the pipe leading into the sensor
Oh alright...
you need some bike carb balanceing gauges....they are used to adjust the linkage to all 4 carbs so they open at exactly the same time and are good for finding probs ........
they have little inline screw valves to dampen the pulse so you get a steady reading
mk3ste
17-10-2021 10:09 AM
07-10-2015 12:56 PM
