Grey injector fitting kit
Old Jul 13, 2007 | 01:14 PM
Mark_w's Avatar
Mark_w
Default Grey injector fitting kit
Has anyone got the picture which shows how to fit a greys fitting kit.
regards mark
Old Jul 13, 2007 | 01:32 PM
GARETH T's Avatar
GARETH T
Old Jul 13, 2007 | 01:33 PM
GARETH T's Avatar
GARETH T
remeber the cap needs sorting
Old Jul 13, 2007 | 01:39 PM
Mark_w's Avatar
Mark_w
Cheers gareth i have been told not to bother with caps or cut them right down...if you dont need them,what is their purpose?
mark
Old Jul 13, 2007 | 02:51 PM
Billabong's Avatar
Billabong
Greys weren't original equipment for a turbocharged YB. By modifying the end of the caps you retain the correct length, and therefore a better/safer fit into the inlet. Fitting unmodified caps affects the flow/spray pattern in a negative way for the YB.
Old Jul 13, 2007 | 03:03 PM
Mr RS500's Avatar
Mr RS500
What do you do to the caps ?? my escoss rally car hasnt got the caps fitted
Old Jul 13, 2007 | 03:09 PM
Mark_w's Avatar
Mark_w
Apparently you dont need the caps,but if you do put them on you need to drill the end right out or cut the ends off.
mark
Old Jul 13, 2007 | 03:16 PM
Mr RS500's Avatar
Mr RS500
mark
Thanks Mark
Old Aug 13, 2007 | 02:25 PM
Mark_w's Avatar
Mark_w
Update...i have found out that the caps are there to hold the components on the injector as apparently it is a pain in the arse when putting them into the manifold without them
bttt for the other fitting kit thread
mark
Old Aug 13, 2007 | 02:51 PM
GARETH T's Avatar
GARETH T
make sure the caps have either the ends cut off, or the pinical hole drilled out
manuel boeckx
13
Oct 3, 2015 02:29 PM
Porplus12
Sep 10, 2015 07:20 PM
Dr. Ickxs
Aug 15, 2015 11:34 AM
track.focus'd
Aug 12, 2015 05:53 PM
Perfmr2
Aug 6, 2015 07:30 AM
