White NMS Saph Cossie on A1
Old 28-08-2007, 06:19 PM
  #41
scoooby slayer
scoooby slayer's Avatar
surge...on a T4?
yeah mate engine cannot consume 33 psi below 5400 rpm so boost has been caped at 26 psi. its got a pair of bd14s though and the inlets only a 4x4 plenum though and head isnt ported to the max. nms call it a middle of the road head. im pondering on eec iv inlet and full head port saw someone who does it for about £1200 gns ? or something like that. should see about 530 then. do you get no surge atall then on your t4 ?
I'd go for the EEC IV Inlet if i was you, the head work on mine by Karl was 2.5k really mine with a T38 on @ 440bhp isn't enough for the spec really mind you' i've told Karl to just chuck the boost at the T38 so it should be fun until it pops..
your head must be capable of loads more then mate. wana swap
It is mate, that's why i'm going GT30 in a few months
The WHOLE car is capable, Quaife diff, Quaife gears..bla bla..
you should be easily cracking the magical 500 then mate
Old 28-08-2007, 06:24 PM
  #42
NEIL A
NEIL A's Avatar
Im getting a custom one from AVA same as rapidcossies with a bigger throttle body , sorry couldnt give you a price as its getting done along wihth a load more work.
Think the ones Mike Rainbird sells have been tested for flow.
Old 28-08-2007, 06:57 PM
  #43
NEIL A
NEIL A's Avatar
Staffi : What spec is your head just trying to gauge how much power my engine could make, as im running the same turbo as you with lots of head work.
Old 28-08-2007, 08:22 PM
  #44
Staffi
Staffi's Avatar
Neil, the spec is Karls own special cams etc
2wd YB Cosworth head ported to NMS Stage 2 spec 26.5mm inlet ports
25.5mm exhaust ports, NMS doulbe valve springs, bronzevalve guides 138.60mm
Pair of NMS high lift cams ground from new blanks
set of 8 coswirth exhaust valves
set of cam followers
Mountune WRC head gasket
cams timed to 110deg exhaust 115 deg inlet..
And breathe...............
Old 28-08-2007, 09:33 PM
  #45
NEIL A
NEIL A's Avatar
Sounds like a good spec.
My new head is cnc big port(with extra work by ava)
1mm oversized ferera valves
Kent doube springs
Titainum Retainers
Mountune cams
Multi layer steel headgasket
Will be good to see what differance the big valves and extra porting will make as ava did a similar engine that made 360 ATW.
Old 28-08-2007, 09:38 PM
  #46
rapidcossie
rapidcossie's Avatar
yous will be a flyer Neil
Old 28-08-2007, 09:43 PM
  #47
NEIL A
NEIL A's Avatar
Hope so would help make it worth the wait
Anyway back on topic what power did your car make on the eec iv inlet Euan before you had to change.
Old 28-08-2007, 09:45 PM
  #48
rapidcossie
it made 453 on the EECIV one mate.
Old 30-08-2007, 05:52 PM
  #49
col cos1
col cos1's Avatar
4 sure
Old 30-08-2007, 05:55 PM
  #50
scoooby slayer
was that at the wheels i take it ? if so that must be over 500 at the flywheel
Old 30-08-2007, 05:56 PM
  #51
rapidcossie
yeah that was 453 ATW prob about 495 bhp fly
thats how it ran at Daddy thrash.
Old 31-08-2007, 02:15 AM
  #52
NEIL A
NEIL A's Avatar
Thats the one thing that gets me on this site how some people claim power ATW some ATF and some Dyno figures. I take it bench dyno figures are the most acurate?
Old 31-08-2007, 02:57 AM
  #53
RWD_cossie_wil
RWD_cossie_wil's Avatar
with a mildly ported head, and plenty of boost, do you recon you could see 500 bhp /500 Lbs of torque? You see a lot of 500-520 BHP engines but with a crap torque figure, some even not making 400Lbs/Ft
My T4 saff is on 25/26mm head with std cams, a 4x4 plenum, 850cc injectors etc, and holds 2.5 bar, not really had a chance to drive it yet as I have been doing a few jobs on it, and converting it to RWD from 4x4 . It has been estimated at 450BHP ( which I think is a conservative estimate), and was certainly stupidly fast as a 4x4, can't wait to give it some in 2wd form
Old 31-08-2007, 11:40 AM
  #54
rapidcossie
Thats the one thing that gets me on this site how some people claim power ATW some ATF and some Dyno figures. So what is the best to claim???? I take it bench dyno figures are the most acurate?
in car ATW figs are the most accurate Neil.
Old 04-10-2007, 09:55 AM
  #55
scoooby slayer
has this been on the rollers yet ? just curious what power it is
Old 06-10-2007, 08:45 AM
  #56
Stu @ M Developments
PassionFords Creator
Stu @ M Developments's Avatar
I have never heard of surge with a T4.
With all due respect you presumably havent had much Cosworth T4 experience then as its only the most likely to surge turbo anyone has ever fitted to a YB ever.
Old 06-10-2007, 10:14 AM
  #57
rapidcossie
Does it surge on a standard head?
Old 06-10-2007, 10:34 AM
  #58
Yes mate, why? What mad plans have you got now?
Old 06-10-2007, 11:49 PM
  #59
rapidcossie
no mad plans Stu just trying to learn more about T4's
charlierothwell
Ford KA
05-11-2015 06:56 PM
IainRS1700T
25-09-2015 06:44 AM
landaqmabba
15-09-2015 07:16 PM
dojj
28
11-09-2015 10:00 PM
Thanasis
07-09-2015 07:33 PM
Quick Reply: White NMS Saph Cossie on A1
