what do i need for 500bhp
#121
JonnyBravo
I agree 100% with what your saying but the problem is who do you listen to???????????? cause i will openly admit i aint capable of specing or building a 500bhp engine
#122
Originally Posted by mechanic28
out of interest why do u want to go up to 500bhp 2wd?when in town where i suppose u will be driving it 80%of time u wont be able to shack off a well set up 2wd 350 bhp one?
i have had 300,330,370,420bhp and i can tell you,if you can drive it NONE of them would get near the 500bhp cos,sorry but thats my opinion
#125
![Pthbbbb](https://passionford.com/forum/images/smilies/smile045.gif)
#126
anyway 500bhp is at the upper limits of any cossie block no matter how well set up u know u r still pushing your luck in ways!
#128
#129
Franco
Originally Posted by Alps Pacino
mechanic28
If your racing around town and in built up areas you shouldnt have the pleasure of a fucking driving license let alone a 500bhp rwd cossie![Rolling Eyes](https://passionford.com/forum/images/smilies/icon_rolleyes.gif)
#130
mechanic28
![Cry](https://passionford.com/forum/images/smilies/icon_cry.gif)
#131
mechanic28
![Clap](https://passionford.com/forum/images/smilies/9c-clap.gif)
track is the only place to have fun in a fast car now anyway.or am i just an old fart!!
#132
No your just scotish, its speed cameras every 4 yards up there, which i have the fucking pleasure of tomorrow on my slow trip to sunny Dundee
#133
JonnyBravo
He has however stripped plenty of new customers engines that have failed in this way though, he has his opinions and tbh I know enough to know he isn't feeding me a pack of lies when he talks to me.
He prices things correctly and doesn't claim to build 500bhp engines on a budget, its a long studded 200 block if you want reliablity end of.
#134
mechanic28
Can't and shouldn't ever push as hard on the road as you can on track
![Smokin](https://passionford.com/forum/images/smilies/icon_smokin.gif)
#135
#137
Franco
Fook off, get to the west coast!
Some brilliant roads free of speed cameras but high volume of camper vans, midges and sheep!
(flying back up there tomorrow-if the fookin airport is open!!!)
#138
Ok...How I would build a 500BHP engine for reliability and decent power/torque.....
1) 200 Long studded block, decked and bored to correct size for a clean bore. Hi pressure genuine cosworth oil pump. WRC spray jets if you want perfection, std spray bar if on a budget.
2) Polished crank, shot peened rods if on a budget, H section rods if you want perfection. ARP bolts mains and big ends. Fully lightened and balanced bottom end ( but not too much weight off, it will loose loads of "oomph" and drivability)ARP flywheel bolts.
3)7.4:1 mahle pistons with valve cut outs
cometic 3 layer steel gasket if on a "budget", propper 4 layer WRC gasket if you want perfection.
4)25/26mm Ported polished head, skimmed flat and CC'd along with the pistons, to ensure accurate comp ratio, also taking into account the thickness of a squashed head gasket
new gen ford followers, BD14 inlet cam, either std or a BD10 exhaust cam depending where you want your power...vernier pullys
5) 4x4 sapphire (500BHP) or small turbo escort cosworth (550BHP) inlet plenum depending on how much power you want, no point in banging on a "swedish" plenum, as at 500BHP you are just loosing response, it does not need the extra airflow yet so keep your gas speeds up...
6) Turbos- T4 with wastegate mod and 360 bearings etc, solid as a rock and can take the abuse all day long.
Or an externally gated GT30, not tried one myself but GT's have a bit of a reputation for being fragile.
7) 850/1000cc a min Injectors on a L8 with closed loop/wasted spark conversions. Full live map, personally I would use MSD as their work is unbelivably good, and the advice you get is 100% no bullshit, if you need somthing you get told, if you don't you don't get sold it, simple
8) Big wing sump with gated baffles
9) Every sensor,seal, bush, gasket and bearing brand new, valve guides replaced.
That should see you right, and be a drivable RELIABLE 500bhp and good torque
Talk to the right people (Ian M500 Cos
), and this spec should be fairly sensible to achive ŁŁŁ wise, if you have good doner parts to start with. If assembled correctly it will be a monster
Also worth considering is the ancills you will have to upgrade, suspension, drivetrain (box, diffs, clutch), fuel system ( pumps, lines, filters), cooling system, intercooler, brakes, wiring loom will 90% need changing due to poor signals from a 15 year old loom, fuel pump wiring for the same reasons, hoses, headertanks, etc etc...
To get a car to a sensible spec for a 500BHP car will leave you very little change out of 10K....if any, probably cost a LOT more when you consider the whole package..
Again, take it from someone that knows
#139
Again, take it from someone that knows![Surprised](https://passionford.com/forum/images/smilies/bigcry.gif)
#140
Originally Posted by Shorty
dingy I heard about what power yours made, fair play, that must be SCARY in a MK2! ![Clap](https://passionford.com/forum/images/smilies/9c-clap.gif)
#141
Block is like new.
Block is not the weak point is it LOL
Mine was the shitty cosworth oil pump - i'm using a 10 quid pinto pump next time LOL
#143
I meant a off the shelf chip prob wont do, Didnt know you could live map L6? thought it had to be L8 atleast?
Originally Posted by Dicko&Sarah
tbh i spoke to karl about doing my car and he is the only person willing to map my car with the t4 and 83lb siemens injectors still on l6 ecu ![Top](https://passionford.com/forum/images/smilies/smile011.gif)
Serial Datastreaming output.
Error Logging.
Closed loop fuelling.
Anti Lag.
Launch Control.
Almost 100% reliabilty.
Not to mention the transient injector control is better giving greater driveability and fuel economy and it has decent idle strategies for when its cold due to being voltage referenced, unlike the ECU's before it.
Plus, some features on their way to you arent available for L1 or 6 either, such as Closed Loop BOOST Control.
Teh rest of the topic seems clear though, but i find the 205 block is fine for 500bhp. Dont forget to install a decent fuel system and rewiring the fuel pump and ECU is normally a requirement. Finally, ensure you have injectors that will run no more than around 75% flat out. Dont be daft and push your injectors to the max at this level, it will end in tears and they will definately be yours.
#144
Originally Posted by JonnyBravo
Are you using long studs Dingy?
However if i was doing this again from a new block i wouldn't bother cause its not required.
#145
My old RS500 which was just over 500bhp, was on the standard 500 block and L6 with the 8 injector set-up on eight greens, air injectors and T4. Standard headbolts with a wire rung block.
#147
First of all Alps ......... are you actually rebuilding or leaving the engine in situ and just upgrading parts to acheive the 500 marker ?
If you leaving the engine in and just want to replace parts thats what I would do .
I successfully ran a T4 8 green set up with no less than 36psi on a 205 Block and standard bolts and a Cometic headgasket when they first came out , infact Paul from PJ let me have it cheap because it was an unknown entity to him so I was a test mule ......... and the whole thing worked faultlessly for me right up until the day I sold it to the car to him .
#148
Caraholic
200 blocks tend to crack around the studs, hence why I use the long versions.
205 blocks tend to crack in the block WALL.
Obviously there is a big difference
. The former can be recovered with reverting to long-studs, the latter gets turned into a nice coffee table
There is a restriction in the 2wd inlet manifold, which can only be removed with mods to the elbow. Fitting a plenum spacer is as much use as a chocolate teapot without this mod
Rgearding the Scandanavian cars that do it the "cheap" way, I have spoken to a well respected Swedish tuner about this, and he says that it is down to financial reasons that they don't long-stud them
. Also, he said that the fact that these Scandy cars tend to do VERY low mileage means that they last quite a while with the standard bolts, and the kind of mileage that a UK car would see, would take most Scandanavian's 2-3 years to equal.
Most UK cars do 8-12k a year (12,000km to 19,000km) and so the head lift issue with the standard bolts is not so much of a problem, when you replacing the gasket every 2-3 years compared to annually on a UK car that is actually used regularly
Just like there are lots of different T34s, there are lots of T4 variants, and you need a minimum of the 57 trim version to break into the 500bhp arena (which flows 48lb of air).
You then need a suitable ported head (which requires the awkward exhaust ports to be machine ALL the way through, not leaving the standard 22mm size in the middle like most seem to do
), or you won't get past 460bhp.
I would also personally like to see 7.2:1 (maybe a smidge higher if a good ECU was being used), to enable big boost figures AND high ignition values.
Cams are also critical, but these really just move the power around, so it depends on how you want it to drive. A mild exhaust cam (such as standard), will help it come on boost earlier, but at the expense of ultimate top end power....
![Raz](https://passionford.com/forum/images/smilies/tongue.gif)
#149
decide who is going to tune the car for you, then follow their suggestions.
much easier than taking 25% from one, 25% from another and 50% from the third, and ending up with something no one wants..
and of course tuners are going to say different things.
each has their own method of doing things!
#150
Caraholic
#151
#152
Caraholic
#153
and it doesnt need someone to die for life to change LOL
#158
I can't remember what it was, but you said the same thing then
You'll have to wait 60 years - but then you'll of popped off before me
#159
Cheers,
WD
