Aeroquipped fuel lines..Do they smell??
Football Cwazy
ever since i've had the cossie at the new house ( in the garage ) i've noticed that i can smell petrol fumes from the rear of the car, i've got underneath and there are definitely no leaks
everything is 'quipped underneath from the pump/filter to the front of the car.
does it let vapour out at the joints or summat? or do i have a problem i need to fix!!
Football Cwazy
it's a possibility i guess....but i had a mates 4x4 saff in the garage for a couple of days last week, his didn't smell at all ( prompting the missus wanting to keep that one )
My 3 dr was exactly the same Martin...makes you paronid
Football Cwazy
it's just annoying really....we have a door from the house into the garage, everytime we go near the area of the garage we can smell fuel lol.
i'm not paranoid, if it blows it's insured
although i do turn around everytime i turn the light on in the garage, just in case
1st to 200 without NOS
Originally Posted by jon@work
if it's rubber lined hose, then yes it will, after time, smell
if it's teflon lined, then it won't
couldnt trust mart with a full tank lol
I've used PTFE lined hose in the car like Chris S and there is no smell whatsoever.
Not sure about it being expensive though as I still haven't been billed for it yet
Yep....it's the aeroquip line for fuel......It was specified by Karl, who put me on to the supplier.
Check the connection to the tank....I remember it was a ba-tard to get on....... but the rest went on perfectly.
Did you remove any of the fuel lines when you removed the rear beam....???
To play it safe, I'd check all of the connections, as this will probably be the first time they've been checked since they were fitted at the same time as the new engine.
I used to check everything about every six months, but never got around to checking the fuel lines since I fitted them.
ie vapor in the air
PRO-LINE MOTORSPORT
28-09-2015 09:54 PM
