Fault reader codes....
Old Jun 20, 2007 | 05:56 PM
warleydaddy's Avatar
warleydaddy
Default Fault reader codes....
Is there a site on the net where i can type in the fault codes,for it to tell me what that fault is??
I have the codes off the reader,but need to find out what they are???
Cheers in advance,
Pete..
Old Jun 20, 2007 | 06:01 PM
jonesymk2's Avatar
jonesymk2
what make is it
Old Jun 20, 2007 | 06:07 PM
warleydaddy
VW Golf Turbo.....
Pete..
Old Jun 20, 2007 | 06:20 PM
jonesymk2's Avatar
jonesymk2
no what make is the fault code reader,sorry my fault
Old Jun 20, 2007 | 06:21 PM
warleydaddy
Ohhhhhhhh i dont know
I just have the fault codes?? I didnt think it matterd what the reader was?I thought the car just gave you a fault car for the car???
Pete..
Old Jun 20, 2007 | 06:23 PM
jonesymk2's Avatar
jonesymk2
oh right ok,ive got a fault code reader here but not sure if it does vw
Old Jun 20, 2007 | 06:30 PM
jonesymk2's Avatar
jonesymk2
i will have a look for the book later and let you know if thats any help
Old Jun 20, 2007 | 06:43 PM
SteveB's Avatar
SteveB
Need the following info and I'll look on Autodata....
Engine size, petrol or diesel, turbo or non turbo and engine code if poss and then finally the code/codes you have
Steve
Old Jun 20, 2007 | 06:45 PM
warleydaddy
Hi Steve....
Dont have engine code im afriad... but the codes are 17536,17705,17956 and EOBD P-0171
Its a Y-reg Golf GTI 1.8 Turbo.....
Pete..
Old Jun 20, 2007 | 06:55 PM
Billabong's Avatar
Billabong
OBD II fault codes:
http://www.peacockandpurvey.co.uk/fa...e_library.html
P0171 System Too Lean (Bank 1)
http://www.vagweb.co.uk/forums/post-2222.html
17536 - Long term fuel trim, entire speed/load range, bank1- system too lean
17705 - Pressure Drop betw. Turbo and Throttle Valve (check D.V.!) / 17705 P1297 Connection turbocharger - throttle valve pressure hose
17956 P1548 Boost Pressure Contr.Valve Open
This looks useful:
http://wiki.ross-tech.com/index.php/...ry:Fault_Codes
e.g. 17705 code - http://wiki.ross-tech.com/index.php/17705/P1297/004759
Old Jun 20, 2007 | 07:05 PM
SteveB's Avatar
SteveB
As Bill has given you info I'll add a little more....
17536
Possible cause - Air leak, fuel pressure problem
17705
Possible cause - Hose leak (turbo)
17956
Possible cause - Wastegate problem
EOBD P-0171
Possible cause - air leak, faulty MAF sensor (what a surprise on a VW...lol), fuel pressure problem.
Steve
Old Jun 20, 2007 | 07:14 PM
Billabong's Avatar
Billabong
Sorry Steve, wasn't trying to steal your thunder - I got side tracked reading posts about faulty VW's and then remembered why I started looking
Old Jun 20, 2007 | 07:35 PM
SteveB's Avatar
SteveB
Every little helps.....
Old Jun 20, 2007 | 08:14 PM
warleydaddy
Are pair are FUCKIN LEGENDS!!!!!!!!!!!!!!!!
Thank you SOOOOOOOOOOOOOOOOOOO much!!!!
BUT,whats this "MAF" Sensor??
Basicley,the prob were having is,is that the car does boost,but very slightyley,and is VERY slow....Car is a Cat D,that weve repaired,but it drives great,just havin these stupid boost problems!!
Pete...
Old Jun 20, 2007 | 08:31 PM
SteveB's Avatar
SteveB
MAF = Mass Air Flow or Air Flow Meter if you prefer its a very very VW/Skoda/Audi/Seat (basically any car that runs a VW engine) problem area
Old Jun 20, 2007 | 08:35 PM
warleydaddy
Ahhhhhhhh ok cool,so the air flow sensor then..Got a few VEE DUBS in at work,so will take 1 off another,and see if that helps...
Thank you SOOOOOOOO much for the links/answers your put up,REALLY helped me out,BIG TIME!!!!!!!!
Pete...
tankybaby66
Feb 6, 2016 02:24 PM
marky_g
49
Sep 22, 2015 09:59 PM
Si B
Sep 12, 2015 06:49 AM
natehall
Ford Focus (All Models)
Sep 8, 2015 05:13 AM
