3-door tyres??
3-door tyres??
i know this has been covered before but i bought
225/45/17,for the rear of my car as told someone else ran them,but they were a nightmare and scrubed
well im raising the suspension on coilovers hopefully by next week and am getting new rears again,even although ive just spent £150 on the other tyres
i dont want same problems so.............................
205,215 are out 225 is out due not being able to get 40`s so the question is
anyone useing 235`son a 3-door???? have to be 40`s though
and what arch trimming was involved?
Originally Posted by Nash
Col i am running 235/40/17 7.5' rim ET37. Thats on a saph with Konis and i dont have any rubbing unless i am 4 up and go over a BIG bump.
Aslong as you have the right offset you should be fine. I thought there was more room under a 3dr's archs aswell?
there is more room as a rule if you mod them i think mate,but out the factory the saph takes wider i think
i have 235/40-17 on the rear but i have the kit trimmed goodyear gd3's
i also run 215-40-17 on the front wheels are all 8J by the way
i now run 235-40 -17 toyo r888 on the rear these are slightly wider than a normal 235-40-17 road tyre
i run 205-40 17 r888 on the front aswell these are a as wide as a 215 road tyre
all my track wheels are et 25 8x17 and i run 235-610-17 slicks allround
marco
marco
im running 245/40-17 f1 eagles on a 9j wheel with a et15 offset on the rear of my 3dr cossie.....its also on coilovers. It does currently rub a little bit, so some arch trimming is going to be needed but i dont mind as the handling and looks is worth the payoff imo
07-10-2015 12:56 PM
