Boost Controller
Old Jun 17, 2007 | 08:06 PM
3doorcozmess's Avatar
3doorcozmess
Default Boost Controller
has any one got a Boost Controller on there cozzie if so what one and do u rate it, as im thinking of getting one
cheers 4 your input
Old Jun 17, 2007 | 08:12 PM
zippyobrien's Avatar
zippyobrien
havnt got one fitted to a ford, but have fitted them to my old mans last three japanese cars and theyved worked awsomly,
particularly on the evo, used an apexi acvr, and with enough setting up i managed to eliminate the boost spike, this ment insted of hitting 1.2bar (the fuel cut piont) and then droping of to 0.9 bar by 7k, i could make it hold 1.2 bar to the red line.
have alwaysed use apexi acvr boost controller.
will have the same affect on any car, deffinaly worth getting. and some of the new ones also display other information and act as turbo timers to
Old Jun 17, 2007 | 08:42 PM
spenner's Avatar
spenner
Your on dodgy ground speaking about boost controllers on here i think there great ive use them on cossies and rs turbos cant speak for all of them but greddy b spec easy to use and relatively inespensive ive got a profec greddy lot more money but very good
Old Jun 17, 2007 | 08:47 PM
abdr500's Avatar
abdr500
i have a blitz boost controler on my cossy works well
Old Jun 17, 2007 | 09:01 PM
DENNIS's Avatar
DENNIS
i have the Apexi AVCR on my car for 2 years, well worth every penny !!
simple to use ( kind of !! ) so many functions. never gone wrong. and you can control the boost setting at the touch of a buton !! ( could be bad thing in the wrong hands !!! )
it is also safe as if there was a fault it goes open loop ( wastegate pressures ) i have it set @ 6psi !! , it`s also got its own MAP sensor.
i`m in the process of setting up the speed related boost settings to protect the transmission !!!
get one you wont regret it !!!
Old Jun 17, 2007 | 09:13 PM
SS1's Avatar
SS1
HKS EVC V Boost control system on the dash. 3 levels of boost(14/24/34), each setting fully adjustable.
Knock Link system installed to warn of detonation.
timsrs
Nov 13, 2018 11:48 AM
Mark RS
Oct 12, 2015 06:01 AM
fordrallycar
Sep 30, 2015 07:57 PM
stevecfrst1
Sep 30, 2015 05:18 AM
Russ Payne
Sep 25, 2015 08:29 PM
