s2 fuel problems help!!!!!
Old Sep 22, 2004 | 10:32 PM
dans rst's Avatar
dans rst
Default s2 fuel problems help!!!!!
hi i have a s2 rst and last nite it just stoped! the fuel relay was very hot and had melted a bit on the side could someone help tell me why this is happening!
or what i have to do to stop this happening?
thanks
Old Sep 22, 2004 | 11:04 PM
Rs Baz's Avatar
Rs Baz
will it still start mate ???????
Old Sep 22, 2004 | 11:08 PM
Hofajoab's Avatar
Hofajoab
maybe the relay was on it's way out (if they do wear out that is) because usually a high resistance in a circuit (perished wires, dodgy connections etc) drawing a lot of current will generate a lot of heat, hence the meltage.
other than that i dunno, not unless your pump is trying to draw more current, but i think your fuse would blow first as that's what they're for? unless someone replaced it with a higher rating fuse or tin foil
Old Sep 23, 2004 | 07:50 AM
LPS's Avatar
LPS
Maybe the fuel pump has gone high resistance and over loaded the relay, it used to happen alot on the old 2.8i capri's (on all 3 that I had).
Rob Wells
Ford Mondeo Including ST
Apr 18, 2023 12:19 AM
JK12
33
Apr 26, 2021 12:09 PM
15
Oct 7, 2015 03:43 PM
natehall
Ford Focus (All Models)
Sep 8, 2015 05:13 AM
RSBryden
Sep 6, 2015 08:39 PM
