please help !!!!!!!!!!!!!
Old Jun 17, 2007 | 04:28 PM
tob4x4's Avatar
tob4x4
Default please help !!!!!!!!!!!!!
can anybody show me a simple diagram of the radiator fans of a 93 4x4 cosworth sierra i need to test the fans but would like to know how they are controlled and how to power them manually thanks for your help overheated twice now need to get them sorted even a in car switch will do
2 plugs but where are the swithches and what terminals need to be crossed
Old Jun 17, 2007 | 04:33 PM
xr4x4rs's Avatar
xr4x4rs
easy way to check you fans work and to eliminate the fan switch is to by pass it
so passenger side of the rad at the bottom is where you fan switch is connected
take the plug off and put a loop of wire in there from one pin to teh other
this should turn the fans on
if it does then replace the fan switch
if it doesnt then you need to check the fuse and relay in teh fuse box
Old Jun 17, 2007 | 04:45 PM
SillyFezzaMk1's Avatar
SillyFezzaMk1
Rubber Rhino Crew
what he said ^^
